diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Jordans in GM's MLTL boxes sounding great - Click HERE for Original Thread
KCHANG
Two weeks ago I built two boxes for my Jordan JX-92S drivers based on GM"s 40" MLTL design. The boxes have a triangular cross section. One additional twist I put in was to use a relatively wide and tall front baffle, about 17.5" wide and 60” tall.
The result was surprisingly good. The bass, although a bit shy and not too deep, is really not bad considering the size of the drivers and that the speakers are far away from the walls. The imaging is very good, and the soundstage is wide and deep. The tonal balance is quite pleasing. I did not use any baffle-step correction.
Before I tried GM's MLTL design, I was not too happy with what I got from the Jordans on open baffles or sealed boxes. I was about to give up on them. I decided to try the MLTL design mainly because it was such a simple project, and I did not expect much from the design. Somehow the MLTL design works, and I need to figure out why, but I am surely glad that I did not give the Jordans away.
As testament to the good sound of the Jordans in the MLTL boxes, my wife was listening to two Pink Martini CD's she just bought through the Jordans, and she was very impressed by what she heard. She commented on how clear the sound was, and how she could sense that the music was performed in a hall. She is not an audiophile and is normally very picky and was rarely impressed by the many speaker projects I tried, and I was surprised that she talked about the “hall” sound like an audiophile would do. She thought that the Pink Martini CD’s sounded better through the Jordans than through my big system using B&G RD75 drivers and eight 18” woofers for dipolar bass, although (apparently to avoid hurting my feelings) she emphasized that her preference was limited to the two particular CD’s. I have to say that listening to the Jordans in the MLTL gave me the urge to go back to tweaking the B&G system, and perhaps with some digital EQ the B&G system will leap-frog over the Jordans to be again the clear winner. We shall see.
A big thank-you to GM.
Kurt
GM
Greets!
You're welcome! I assume you mean the 48" version. WRT tweaking your reference system, I imagine it's much more 'accurate' down in the midbass/bass than the pipe, which is somewhat 'colored' (resonant), giving you that 'hall' effect. For a somewhat more 'accurate' reproducer, consider my original 30+" pipe design, which AFAIK is now posted on the Jordan site.
FWIW, I've never built/auditioned any of the various versions, but if I did, it would have at least a 30" wide baffle if not up against a wall or near/at a corner.
GM
Cortez
Mee too... :)
Is there any base article abount MLTL ? What is it exactly, how it works acoustically, etc ?
(Till now i didnt found any usefull stuff on the net about this type of enclosure...)
MJK
I guess I'll take credit for the ML TQWT and ML TL labels. Basically I got the idea when I was designing my first full range driver speaker a few years ago. I was working with a pair of Fostex FE-164 drivers and trying to design a TQWT enclosure for them. I found that restricting the open end using a port had some real advantages for controlling the TQWT's open end output. The port mass loaded the standing wave that existed in the TQWT hence the ML TQWT abbreviation
A few years later I used the ML TL label to describe a tall "thin" tower I was designing for the Fostex FE-208E Sigma driver. I studied some finite element models of the air motion in the enclosure to see how it was behaving at resonance and found that a standing wave existed in the tall direction as apposed to the uniform compression found in a classic bass reflex enclosure. This motivated me to call the design a mass loaded transmission line or ML TL. These types of designs seem to work very well and have bcome quite popular with full range driver DIYers.
If you read the description of the enclosure design used for my Project 4, you will find the following summary of how a ML TL works.
"I have been asked many times about the difference between a ML TL design and a simple bass reflex enclosure. From the outside the two look very similar and performance wise there is not a large difference. I think that the principle difference is the way the air volume in the cabinet is used to provide the spring that interacts with the mass of air in the port to form a resonant system.
In a bass reflex cabinet, the air in the box is compressed to a uniform pressure to form an air spring. Typically no damping material is added to the inside of the box so that the Q of the box remains high and the effective volume of air is predictable from the internal dimensions of the box. The shape of the bass reflex box is not that critical, only the internal volume matters. A bass reflex enclosure can be represented as a lumped mass hanging on a spring. If you displace the mass the entire spring stretches. When you let go, the mass oscillates at a predictable frequency that is a function of the springrate and the mass of air in the port. The key point is that the entire spring stretches linearly. This is a simple one degree of freedom mechanical system.
In my opinion, one of the negative attributes of a bass reflex enclosure is that any strong standing wave resonances in the enclosure will not be sufficiently damped. The lack of fiber in the center of the air volume allows energy from the back of the driver to potentially excite resonances and produce unwanted acoustic output that escapes through the port opening. Some people try and mitigate this problem by placing the port on the back of the enclosure. Placing the port on the back of the bass reflex enclosure may require more standoff from the rear wall and lead to room placement problems. The ML TL enclosure design requires stuffing in the internal volume of the enclosure. The presence of this stuffing is part of the design cycle and the amount and location is accounted for in the design process.
The ML TL enclosure can be thought of as a form of transmission line where quarter wavelength standing waves are used to provide the spring for the mass of air in the port. To physically model a straight uniform TL, clamp a yardstick to the edge of a counter or desk and pluck the free end so that it starts to vibrate. The vibration pattern is analogous to the air velocity in a TL. The TL's air velocity is zero at the closed end as is the yardstick's motion at the clamped end. The TL's air velocity is a maximum at the open end as is the yardstick's velocity at the free end.
There are two ways of changing the frequency of vibration for the yardstick. If you shorten the length cantilevered off the counter, the frequency of vibration will increase. Make the length longer and the frequency decreases. This is how straight TL's have traditionally been tuned by adjusting the length. The second way of tuning the frequency of the yardstick is to add a lump of mass to the free end. Put a piece of modeling clay on the free end and watch the frequency decrease. What I have done to the classic TL is put a lump of mass at the terminus end using a restrictive port. For a given frequency, I can shorten the TL (make it stiffer) increasing the tuning frequency and then add mass (air in a port) to pull the frequency back down and get a similar tuned result. One other benefit of having a lump of mass at the terminus is a rolled off port output above the first quarter wavelength resonance. This result is similar to a bass reflex port's response. I did this first with the ML TQWT and then with a straight TL. If you try the yardstick analogy, I think by changing the length and adding mass to the end you can demonstrate to yourself exactly what I am doing in my MathCad computer models."
Hope that helps,
Cortez
Hi Martin !
Oh, it would be cool, to learn more about acoustic with this method...
In your opinion is this method enough precise to modell the sound ?
> Hope that helps
Of course, and thanks for the explanation !
I would like to ask a few thing more:
If understand correctly, a MLTL is a BR + a TL, with a common tuned resonant freq.
Maybe the tapered type TL-s (eg: Sd -> Sd/2) are similar to an MLTL ?
What are the MLTL's drawbacks related to a classic BR, or a classic TL ?
And whats the difference in efficiency between them, whats the order ?
If i'am right The benefits are: shorter line (smaller box), and a stronger
cutting of higher frequencies (above the tuned freq).
There is a site about resonances in air columns:
http://hyperphysics.phy-astr.gsu.ed...ves/opecol.html
But i cant decide, that a TL is wich type of these...
The side with the speaker is an opened or a closed end ?
At the closed end the air doesnt move, but at the speaker there is > 0 speed, isnt ?
A closed pipe resonates deeper related to an opened type. When we put the port to the end,
we are getting closer to the closed state and therefore our resonance getting lower too ?
Or maybe the port is halfway a closed end, and halfway an open end, so the half of the energy
radiated by the cone's rear surface is going out from the box through the port, and the other
half part is reflected due to the acoustical impedance of the port and therefore halfway it behaves
like a closed air column resonator, and halfway like a BR that radiate the sound from the port in
the correct phase. Am i right ?
I guess, i understand a pure BR, and a pure TL alone, but i'am unable to imagine they together.
Otherwise when there is a standing-wave in a box, like in a MLTL, from where we hear it,
through the cone, or just from the vent, when the phase is correct to the front radiation ?
I have a pair of Fostex FE-166, and now they are in a small, self-designed horn, but i'am
not completely satisfied. In your opinion, an MLTL could give a better bass performance ?
MJK
I was using the FEM model to calculate and correlate the frequencies and mode shapes of the standing waves in different enclosures. To extend this to predict SPL at a specific position could probably be done but I have never tried.
Yes, I guess a good analogy would be to combine the BR and TL behavior to explain the ML TL performance. A classic tapered TL is not a ML TL since it will produce response at the open end from the higher order standing waves while the ML TL will suppress this output. A ML TL can have a tapered internal geometry with a prot at the open end. The best way to try and understand the differences is to model some of these geometries in the MathCad worksheets and review the results. Keep in mind that there is not clear line that separates the different designs but more of a blurry region as one transitions froms a TL to a ML TL to a BR.
I think you have the basic advantages stated above. Everything is a compromise and I do not believe any one is beat in all situations. All three will have the same efficiency and all roll of at 24 dB/octave below the tuning frequency.
Typically the speaker is placed at or near the closed end. The air at the closed end does not move and is the location of maximum pressure. At the quarter wavelength frequencies, the pressure at the closed end becomes large enough that it will significantly attenuate, and almost stop, the driver motion just like in a BR enclosure.
The best explanation/expereiment is the ruler clamped to the edge of a table. The ruler will vibrate with quarter wavelength displacement shapes. Adding mass (the air in the port for a TL) with a lump of clay will lower the resonant frequency.
When there is a standing wave in a TL, the driver motion is attenuated and most of the sound is produced at the open end or at the port for a ML TL. The driver's contribution to the SPL is minimized. Again, if you run the MathCad worksheets for a classic TL with no driver offset you can see this in the plotted SPL responses.
The FE-166E driver has a very low Qts so if you put it in a ML TL you will definitely need a correction circuit to balance the SPL response. I really don't know anything about the FE-166E or the horn you are using so I really cannot offer any opinion about your results. If the bass output from the horn is weak, you might try a correction circuit to see if just rebalancing the SPL helps the situation.
Hope that helps,
Cortez
Aham, i guess, i starting to understand it... Its just like the mass on the spring.
On the resonant frequency its hard to move this system, even so the mass moves with a huge amplitude.
But when the front radiation doesnt matter, why is the TL better, related to a simple closed box,
where only the speaker radiates ? Or due to the resonance, it means double energy ?
Still a question for me: Ok, the speaker is a closed end, but the open end is opened, isnt it ? :-)
If yes, this is just a halfway opened air column, which ideally resonates only on L/2 and not on L/4.
I would understand if we used an L/4 TL + a port (mass loading) cause these together would form a L/2 TL.
A MLTL also resonates on upper harmonics, cause the port
doesnt pass these freqeuncies, but reflect back, doesnt ?
Colin
Rewinding the thread a little ...
It's at
www.ejjordan.co.uk/diy
There's also a link to a page with GM's MLTL designs for the JX125 and JX150 bass drivers
MJK
I am sorry but I have no clue what you are saying above. I think that the best way for you to gain an understanding of TL's is to do the math and determine what geometries and boundary conditions generate half wavelength and quarter wavelength resonances.
Cortez
I cant understand, that a TL with a vent at the end, how can resonate at the same
frequency, like a closed air-column. Or a simple TL is not an opened air column ?!
Otherwise, when the front radiation doesnt matter, why is a TL better, related to
a simple closed box ? Maybe due to the resonance, it means double sound-energy ?
Thanks !
MJK
quote:
I cant understand, that a TL with a vent at the end, how can resonate at the same frequency, like a closed air-column. Or a simple TL is not an opened air column ?!
It resonates just like a normal TL, the added mass at the end allows the line to be shorter for the same tuning frequency.
quote:
Otherwise, when the front radiation doesnt matter, why is a TL better, related to a simple closed box ? Maybe due to the resonance, it means double sound-energy ?
If you put the same driver in a closed box and a TL are you going to get the same f3 frequency? The TL has added bass frequency extension compared to a closed box. It is very similar in performance to a BR but the box resonance is damped so that the bass tends to be tighter with less boom.
quote:
A MLTL also resonates on upper harmonics, cause the port doesnt pass these freqeuncies, but reflect back, doesnt ?
Yes, the ML TL does have higher frequency standing waves and the port does significantly attenuate the strength of these resonances. The higher frequency modes can be seen in the SPL response calculated for the ML TL, look at one of the simulation results from Projects 3, 4, or 5 to review the driver and port SPL output as a function of frequency. Another variable used to control the higher modes is the driver placement, this will reduce the excitation of the higher modes.
Cortez
Thats all clear, my problem is, why a TL with a full-surface vent resonates like a closed pipe.
Hopefully not, just trying to understand the theory. :)
Ok, i accept, but why ?
You said, that at a MLTL the front radiation isnt remarkable.
At a BR design, the point is the summing of the front and the rear radiation, isnt ?
Otherwise, if we "mass-load" a classic L/4 TL with a port, we will get a L/2 TL ?
MJK
A ML TL will resonate with a quarter wavelength mode just like a classic TL. Go back to my ruler analogy, without the mass on the end the shape of vibration when you pluck the free end is the same as when you add the mass on the end. The mass on the end allows a shorter ruler overhang to get the same frequency of vibration as the plane ruler.
You need to download something simple like WINISD and explore closed and ported box designs using exactly the same driver. If you do this then the answer will be clear. A closed box will raise the resonant frequency of the system where a ported box (or TL) is tuned to the driver's free air natural frequency and the bass will go lower.
I doubt I said that, I don't even understand what that means.
Yes, and so is the TL or ML TL. At resonance most of the acoustic output comes from the opening (port or open end) and the driver's output is at a minimum. You sum the two outputs, taking into account the phase angles between them, to determine the total system SPL output.
Cortez
Strange, i thought i was clear:
As i said, i understand now the priciples of MLTL, my problem isnt that, but this:
Why a TL with a vent resonates like a closed pipe (L/4) ?
Cause based on the web-site, ideally an open air column with
length L resonates not on L/4, but on twice as much freqeuncy
(it resonates first on L/2), related to a closed pipe.
If we would "mass-load" a classic L/4 TL with a port, we will get a L/2 TL ?
You said, that a port virtually lengthen the TL line.
If there is a L/4-TL tuned to 40Hz, with a port, we can legthen
the line again, and get a HalfWave TL tuned also to 40Hz. Not ?
MJK
That website is not very clear. By open end tube they mean open at both ends. By closed end tube they mean closed at one end and open at the other. A TL or ML TL is closed at one end, typically near the driver, and open at the other end where the TL or port exhausts into the room. A ML TL is still basically a quarter wave tube. The length of the port is almost insignificant compared to the height of the cabinet where the standing wave exists.
Cortez
Okay, i'am understanding now...
There is on other site: http://www.walter-fendt.de/ph14e/stlwaves.htm
here is the tube with one side open and the other closed, and the resonance is really at L/4...
When the port lengths the line, what would happen when we would add the port to a L/4 TL without shorting the line ?
It could be a L/2 TL (virtually a 2 times long TL as without the port) ?
Because then the harmonics would be also double lower, wouldnt ?
MJK
The port does not lengthen the line, it mass loads the line lowering the tuning frequency. Then shortening the line with a port raises the tuning frequency to the starting point. For example, I think my Project 4 ML TL is tuned to about 40 Hz. If this was sized as a classic constant cross-secton TL the required effective length would be as shown below.
L = (344 m/sec) / (4 x 40 Hz) = 2.15 m or 84.6 inches
If I remember correctly the ML TL enclosure is about 40 inches tall, much shorter then the calculated length without mass loading shown above. That is the advantage for the ML TL, the size is greatly reduced. If I had added a port to the 86.4 inch long classic line the new tuning frequency would be much lower then 40 Hz.
If one end of a line is open and one end is closed you can only have a quarter wavelength transmission line. You cannot have a half wavelength transmission line with these boundary conditions. You can have a quarter wavelength transmission line that is tuned way to low to get optimim bass SPL output.
Cortez
But logical the port makes our line longer, doesnt ?
Like when the stuffing increase cabinet size at BR designs.
You have right. But then a "closed cone" should resonate on L/2, right ?
Or that would be the MassLoaded QuarterWaveLength VoigthPipe ? :eek: :)
MJK
Longer then which line? If you look at the classic line length, the port makes the required line length shorter 84.6 inches ----> ~40 inches. In the ~40 inch line the port is probably only 1 or 2 inches long so I guess one could claim that the port is adding a small length. I think we are getting into an accounting type discussion, the big advantage of the ML TL is the reduction of length form 84.6 inches to ~40 inches.
A cone closed at one end and open, or ported, at the other is still a quarter wavelength pipe. See my Project number 2, it is about the ML TQWT.
I'll rephrase my previous statement :
If one end of a line is open and one end is closed you can only have a quarter wavelength line. You cannot have a half wavelength line with these boundary conditions.
Cortez
Then the original TL line without a port.
Yes, of course, the required, physical length will be shorter, but because the logical line is longer.
The port makes the line length logical longer, therefore can we shorten it physical,
just like when we build a little bit smaller BR box, when we stuff it.
And whats the benefits this tapering design (called also a voight pipe, rigth ?) related to a simple, straight one ?
Ok, understanding. (I based my idea on the site's 3rd figure about a closed cone)
Otherwise whats your opinion about using muffler-like acoustic filters in a TL design to reduce the upper resonance, harmonics ?
Is it possible to achieve this witout making our TL unoperable at low freqs ?
MJK
That seems like a confusing way of looking at the problem. I tend to work with physical dimensions and tuning frequency. That seems logical to me. But if that rational works for you ......
The TQWT is more efficient at transmitting bass and damping the standing waves as a result of the larger open end area. The larger open end area will generate an acoustic impedance that has a bigger resistive component so more energy will be extracted from the standing wave and transmitted into the room. The reflections back into the pipe will be lowered so the peaks in the response will be attenuated. If you look in one of the attachments to my alignment tables, you will see a study of TL shape and the output for each. The downside is that the strong pipe output will be difficult to control in the midrange. If you continue to increase the open end area, it will eventually become horn loading.[/QUOTE]
I have never tried this approach. I have not reconfigured my worksheets to simulate this geometry or seriously thought about designing and building such a configuration. I guess it would work but the complexity in design and building a system would be higher.
Cortez
And whats your view about the Karlson phenomenon ?
http://home.planet.nl/~ulfman/theory.htm
Can be used somehow for TL-s ?
MJK
I don't know anything about Karlson enclosures. I have seen the site, and pictures of this type of design, but have never looked into modeling or building one. Too many other things to keep me busy.
Cortez
Ok, thanks for all ! :)
pikkujöpö
I also think the GM:s MLTL 48"with jx92s sound really great.
I finished my new speakers few weeks ago, and want to thank the mastermind of this design ,as well as everyone who has built these beautifully sounding speakers and recomended them.
In next days I may try them with BSC.Needed to adjust the tone buttons of amplifier to treble -4db bass +4db in order to make the sound deacent.Also adjusted the toe in as much as possible.
The birch plywood was recomended for the enclosures.Anyway I decided to use the materials easily found from the local store.The walls are made with 16mm MDF and 10mm hardwood glued together,except the back wall that is made with 2x 16mm MDF(there is a picture of them in the full range photo gallery).
At first I was going to make the Konus Essence clones (they look very nice)or mini monitors.Always when listening the bass coming out from these enclosures I'm sure I made the right decision.
Once more.....they sound really great for the money:)
GM
Greets!
You're welcome! Yes, these need BSC if not placed up against a wall or near a corner and I recommend toeing them in per TJ's recommendation.
GM
Colin
quote:
[i]At first I was going to make the Konus Essence clones (they look very nice)or mini monitors.Always when listening the bass coming out from these enclosures I'm sure I made the right decision.
Once more.....they sound really great for the money:) [/B]
I think they sound really great full stop! I went to a demo of some very expensive Linn speakers a while ago and they went loud, they were very detailed ... but they didn't have the musical quality of GM's design, in my opinion.
BTW, I've heard the VTL (the Konus prototype) and I think the MLTL gives a richer and more satisfying bass. Experiment with location - using them against or near a wall you may find you don't need BSC.
Colin
PS Hello to GM.
Landroval
I have thought of trying to add a AC G2Si to my MLTL48 JX92. I probably will try it with Jim Griffins crossover if there's no reason not to. Any reason why I should forget this idea?
I already have two sets of binding posts with them, so I could have the others with the 2-way design and the others with the JX92 only.
pikkujöpö
[QUOTE]Originally posted by Landroval
Now when you mentioned the binding posts ,I remembered one question about the BSC.
My speakers don't have any binding posts,the speaker cable is soldered directly to the driver.Can I connect the BSC to the amplifier end of the cable and maybe even leave it there after finding the correct values for components?
My cable is 4meters long x 5mm2,if it makes any difference.
Colin
I've beefed on elsewhere about the reasons for not adding a tweeter to the JX92 but I guess it's a matter of taste. For example, I thought the Linns i listened to had a very finely etched quality to the HF, extremely detailed but a bit like trying to read in a searchlight. As an experiment, I tried adding a JX53 to my MLTLs. The 53s were crossed at 500Hz, first order, and the JX92 rolled off at the same point. Although the sound was smoother, I felt it lost the depth of imaging and seamlessness of using one unit on its own. A higher order crossover might have had a different result, as I could hear the JX92 three octaves up when I tried it without the 53 but with the LF inductor still in place.
No disrespect intended to anyone here but I sometimes wonder if the hifi industry hasn't distorted our thinking about what we should be able to hear from our speakers, amps, etc. (Discuss, do not write on more than one side of the paper, etc.)
GM
Colin
PS Hello to GM.
Greets!
I imagine the Linn's are much more accurate, so comparing them to my original (short) ML-TL design would be a more fair comparison. The longer pipe may sound more 'musical' due to its 'coloring' the reproduction, but it's just euphonic distortion, much like what you get from a vintage design tube amp, so powering them with an early '60s RCA SET pre/60W amp recording studio combo should be tantamount to having a morphine drip at your disposal. ;)
GM
GM
Greets!
It depends on your HF hearing acuity and/or need for a wider listening 'sweet spot' than the Jordan can provide on its own. JG had these at the last Atlanta DIY Meet and unfortunately I missed their audition, but they were the hit of the Meet and from a technical POV, a ~decent driver match.
Only one way to know for sure, so hopefully you'll try it, compare, and report back to us.
GM
GM
quote:
Originally posted by pikkujöpö Can I connect the BSC to the amplifier end of the cable and maybe even leave it there after finding the correct values for components?
Greets!
Sure! Folks often put the XOs for both speakers in a box on the equipment rack so they can have easy access to tweak them.
GM
Landroval
quote:
Thanks for advice. Maybe I will.
Basically I feel that the upper end of the JX92 is not clean enough. It doesn't have the sparkle of a real tweeter, nor is it smooth enough for my ears. I'm going to give them a chance to prove me wrong though. I moved them to a bigger room, where I can position them more freely and toe in more.
soongsc
As with all full range drivers, some tuning straightens things out. Jordans somehow give slightly better resolution, a bit more realistic reproduction. If you look at the phase response at the Jordan site, there is a phase lag that needs to be compensated for.
GM
Greets!
For sure, there's a fine line between great HF reproduction and just plain unreal. This subject is impacted by virtually all of the signal chain and of course our hearing acuity at various times in our lives, general health, etc., so no 'one size fits all' solution unfortunatel, though some solutions come very close IMO.
With XOs in the lower mids and/or 1st order, keeping timing errors low are essential to a coherent soundstage due to our head's transfer function causing us to be more phase sensitive in the ~200-2 kHz BW and amplitude errors higher up, so I believe if you accounted for the XO's effect on these, they would sound as 'seamless' as the JX92S by itself.
WRT any industry influence, be it mass marketing or 'HI-FI', they're just trying to make a living in a highly competitive market, so they pander to the ~80% of the buying public that doesn't want any of the responsibility required to determining what is the best products for their intended app, and since we are amplitude oriented animals both aurally and visually, whatever initially 'grabs' our full, yet fleeting, attention for whatever reason is the 'no-brainer' choice if we can afford it.
GM
Colin
Hi GM
Yes, agree that my comparison was very quick and dirty. I'll try again when the new version of the JX53 is available and the crossover can drop to the 150Hz region.
I have used conventional tweeter/bass speakers, including a Scanspeak/Elac TL and whereas they sounded clear and open, they lacked the feel of the JX92, where acoustic music seems to hang in the air between the speakers.
Not so sure about the accuracy of the Linns. It seemed to me that they went too strongly the other direction, but then I'm more of a Naim user and their electronics are renowned for tweaking their response slightly. FWIW, the Linns were set up on a stage, with ideal positioning but I didn't think they imaged particularly well. However, I appreciate they are in a marketplace and know their competition ...
GM
Greets!
Can't comment on recent Linns, but the '80s models I auditioned were very 'dry' sounding, i.e. very low harmonic distortion, a hallmark of certain aspects of accurate reproduction, though like the vast majority of multi-driver designs they had timing errors that degrade imaging/soundstaging, so in this respect any decent 'FR' driver would clearly best them.
GM
Colin
The Jordans (and some horns I built in the late 70s) made me realise that I can tolerate a certain amount of colouration in favour of the soundstage and imaging of FR drivers.
Page generated in 0.28053402900696 seconds with 17 queries,
spending 0.01116943 doing MySQL queries and 0.26936460 doing PHP things.
