| tablebeast |
HI, I'm new here and I just aquired a cool device. Its a Grommes / Precision Electronics / Western Electric G5M Tube Mixer. Its a lot like the Altec 1567 Tube mixer but has a lot of important improvements. It has 5 transformer balanced mic inputs, , a line input, tube EQ, and a master gain stage. Basically I want to refresh and modify it. I would like to install DI inputs bypassing the transformer and direct outs for each of the 5 mic channels. It uses both sides of a 12AX7 per channel so I assume there should be sufficient gain for the direct outs. I want to use this as the front end for my DAW. I want the individual outputs for use recording drums and I want to use it as a mixer in its natural state for overdubs, utilising multiple mics into one output. What I'm looking for is any help with this. I could use a schematic if there is one out there. Maybe one of you guys has one of these? How would I go about installing the mods on this? Thanks in advance guys.
Jesse Mesa-Savage |
| kftool |
Hi guys, I have a schematic for the above mixer along with a few of them.
reply if you are so inclined.
Ken fritz, Richmond, VA |
| tubewade |
I have one, but have never tried to modify it. Just used it as is.
A schematic would be very much appreciated. If you want to post it here or send to wadenjulie at netzero dot net I would be very grateful. |
