| Lyerigolfin |
I'd like to know what people thought of this design.
The driver is the 8" dayton quatro SVC 4 ohm.
Dimensions (without stand)
Outer Height = 21.75"
Outer Width = 9.5"
Outer Length = 9.5"
Inner Height = 20.25"
Inner Width = 8"
Inner Length = 8"
.75 ft^3 internal with 13.9" total port length and 2.5" inner diameter (exactly to dayton's spec)
The legs are each 6" (this is what I'm mostly unsure about.) I don't know whether or not they will be real wood or PVC.
There's approx 3" of space between the driver magnet and the bottom of the port. I thought this was acceptable since it was more than the inner diameter of the port.
I'd line the walls with some acoustic dampening material just like dayton suggests.
I already did the driver sag calculation for the dayton quatro 8 and it was somewhere around 2% of xmax indicating that the driver is OK for this downfiring application.
Any comments are appreciated, thanks.
| Cal Weldon |
The drawings look very nice.
If you're worried about the port being too close to the driver you can experiment with stuffing the tube with a little damping when you are done. Listen first, fiddle later.
The legs might not have to be that long.
Cal |
| simon5 |
I built a downfiring subwoofer with a 12 inches driver, the plan I used had only 3.5" legs.
You can shorten these a bit. |
