| Jaka Racman |
| quote: | Originally posted by Bruno Putzeys in another thread
Well if you are very patient and have enough power devices to spend on failed amplifier you could just possibly get a UcD based ampliverter working.
Let's say I would not recommend it but just for the heck of it, here's how it could be done (mono amplifiers only):
1. Make a normal UcD loop.
2. Feed the comparator output to a state machine that alternatively switches the primary and secondary sides.
But here's the annoying bit:
3. Add a protection that will override the comparator output if it hasn't switched for the last few microseconds. Otherwise the primary side will blow instantly when the amp is clipped.
I'm not a fan of ampliverters though. The idea is very elegant, but the bilateral switches on the secondary side make things a bit more complicated in reality than in concept. |
Ampliverter is basically a transformer isolated class D amplifier, so it can be connected directly to the rectified mains voltage. Effectively it is just a SMPS with bidirectional synchronous rectifiers.
Compared to a classical class D amplifier it has some advantages (at least on paper):
- power supply is integrated, so it can be made small
- both pairs of switches operate at one half of the switching frequency, 200kHz in this case.
- there is no stored energy on the secondary, so DC speaker protection is not necessary.
- auxiliary supply voltages require only few turns windings on isolation transformer
I have read of only one commercial amplifier using this principle (Peavey). There are several patents on this topology, but the main one (US 4479175) has already expired. The most recent patents came from Nuforce (class N amps). All designs that I have seen use constant switching frequency and that seemed like a good idea at first. Only when I tried to close the feedback loop in simulation (using triangle derived from the secondary winding) I realized that delays in the modulator and driver chain produce DC offset at the output. I was then toying with PLL used as a modulator until I started to think about Bruno's idea. Variable frequency is not such a problem as it seems. At 200kHz transformer would operate at 0.05T because of the losses, so lowering primary frequency to 50kHz is no problem.
So here is a simulation of proof of concept UcD type ampliverter. It shows that the whole thing is not much more complicated than a commercial UcD amplifier which also incorporates current limiting, soft start and overvoltage protection. Simulation uses S elements as switches to speed up simulation, but i believe that all necessary parts are included. E elements with unity gain represent optocouplers or other digital isolators. Simulated circuit is stable into open and short circuit and is also protected against clipping. The whole concept of variable frequency ampliverter is not limited to the UcD type of modulator, it can also be used with leapfrog modulator or even self oscillating hysteresis modulator. Before I proceed with the final design I would like to know how much some second order effects can be detrimental to the performance of this circuit.
By second order effects I mean unmatched switching times in the primary and the secondary and unmatched delay from the modulator comparator to the primary and secondary switches. As can be seen from UcD vs ZapPulse thread switch transition times have far greater influence on distortion that I have originally thought. Any comments from Bruno, Lars, analogspiceman and all others are welcome. Also many thanks to Bruno for the original idea.
Best regards,
Jaka Racman |
| Jaka Racman |
there is also LTspice file for anyone interested. Many thanks to analogspiceman for using his models.
Best regards,
Jaka Racman |
| classd4sure |
Many thanks to you for this!
Seems like it'll work with mueta.. and possibly single cycle control?
It's been awhile since you've first mentioned ampliverter, great stuff.
Chris |
| subwo1 |
Hi Jaka, I like it! I am interested in taking this route since space is very scarce in my small living quarters. The concept of driving a speaker with a power supply has been attractive to me for quite a while. I first did it several years ago, but it was half class A, half class D.
I may have to wait until winter before I can really study the LTspice circuit. Thanks for providing it. |
| Jaka Racman |
attached is leapfrog ampliverter LTspice file. Functionally, both leapfrog and UcD are equivalent (short, open and clipping protection). Leapfrog requires one comparator and three opamps, while UcD requires three comparators and one opamp. One possible advantage of UcD is comparator operating in inverting mode, so input common mode requirements are relaxed compared to the leapfrog where comparator requires large input common mode range. Also UcD has only one comparator in signal path, while leapfrog has three opamps and comparator. But UcD also uses opamp buffer input stage, so situation is still not very clear. I will probably have to try both solutions.
Chris, I think that single cycle control is only a complicated way of achieving advantages of hysteretic self oscillating design with constant frequency switching. I think that it it can be achieved more simply by adjusting hysteresis with input signal feedforward. Look at US5160896 for that.
Best regards,
Jaka Racman |
| analogspiceman |
Hi Jaka,
I am glad to see you have been up to some serious fun with ampliverters and LTspice. :D The effort you clearly have put in deserves a response in kind. I just want to let you know that I have read your posts and plan to make a more serious response as soon as I can find the several hours it will require.
In the mean time here are a couple of quick comments:
I like how in the UcD-control based ampliverter you seem to have digitally ORed together voltage and current modes without the usual slewing delay glitches during mode transitions (leapfrog in inherently seamless in this regard).
It seems that because UcD control is closed around a second order filter (rather than a first order as in leapfrog), it suffers a kind of overshoot recovery glitch in the face of large amplitude steps (when the feedback loop is momentarily disconnected). Now that you've obviously played with both systems extensively, have you noticed a difference in this regard between UcD and leapfrog style control?
Regards -- analogspiceman |
| Jaka Racman |
Hi analogspiceman,
I must admit that I have been more busy with the design of the state machine than by closing the loop. That's why I used published values in both UcD and leapfrog compensation circuits and threw in "educated guess" (first parts I had in the part's bin) 1k and 100pF value for the extra passive pole in the UcD compensatin circuit.
Yes, I have seen ringing in the UcD response, but hopefully it can be tamed, as actual UcD400 response shows.
I have now started to draw actual schematics. I will draw one for both the UcD and the leapfrog. As far as I can see, leapfrog my end up using even less parts, so I will probably try this one first. I am glad you will comment further, but please take your time.
Best regards,
Jaka Racman |
| Tekko |
| This thing looks like a audio modulated smps to me. |
| classd4sure |
| quote: | | Chris, I think that single cycle control is only a complicated way of achieving advantages of hysteretic self oscillating design with constant frequency switching. |
I think I can easily agree with that. I think I'd like to try out both ... just for some educational kicks.
To compare leap frog so directly with UCD.... hmmmm.
I don't consider that rendition of leap frog to be complete? It was only ever based off of the single ended "known from patent" version, and so the leap frog technique is of course single ended as well. You'd have to compare it to that same singled ended UCD.
The real UCD is of course fully differential, explaining the two input op amps, that it doesn't really need. I'd like to see a fully differential leap frog, I don't have a good enough grasp of the control loop to handle that one myself.
You also mentioned UCD driving into a short? It's not equivalent to leap frog in that respect, you need CMC for that right?
I think the ringing you're talking about is only tamed by limiting the input, somehow, like a LPF?
Chris
PS:
Thanks again for contributing, these are the kinds of threads I really like! |
| phase_accurate |
| quote: | | This thing looks like a audio modulated smps to me. |
That's exactly what an ampliverter is ! The idea is to get rid of one conversion process.
If we look at amps more generally then all of them are audio-modulated PSU's (most of them being post-regulator topologies).
Charles |
| Jaka Racman |
Hi Chris,
yes I am now looking at the differential configuration of both modulators. With UcD, comparator now also sees common mode signal, so one advantage of UcD (in my list) has gone. On the other hand, by applying differential feedback on the leapfrog I was able to omit one inverting opamp.
My problem is that my background is SMPS. In SMPS, anything under 1% error is usually good enough, but not in audio. I am pretty much confident I can hack power stage together and close the feedback loop in a stable manner quick enough (been there, done that). But to go under 1% THD will require me to learn and experience new things, and this will take some time. I am getting a little old and I do not breadboard so fast as I used to. So I simulate more, but simulation is only good to grasp principle not to discover finesse. So by counting active devices I am trying to identify possible trouble spots. For instance, large common mode input range for comparator my force me to think about discrete design (I was intending to use IC, LT1394 for instance).
Best regards,
Jaka Racman |
| classd4sure |
Hi Jaka,
Thank you for that reply.
You again bring up an excellent point. The common mode signal shouldnt' really be a problem... and apperently it isn't according to the performance of the actual modules.
Decent rejection is possible by using high precision components, the caps will degrade it at higher frequency but you can try to match those too. It seems to work great anyway.
So now is a good time to ask.... what's worse? Less CMRR or a non differential setup? I'm kind of leaning towards fully differential as being the better one, as always there's a little something we've got to give up for it.
Trust me I understand the problems with simulation.
Discrete design, certainly seems to be worth it in the long run, not exactly fun for prototyping though. It'll get you pretty good simulations though.
Looking forward to seeing how a differential version of LP measures up to the single ended one.
I'm trying to take a break from simulations for awhile (really I'm just sick of it) but when I get the urge again this thread is my first stop.
Chris |
| analogspiceman |
Ping :D
Will be gone for a week or two.
Haven't forgotten this thread.
:) analogspiceman |
| classd4sure |
I'm sure the eventual reply will be well worth the wait :)
Have a good.. vacation?
Chris |
| Jaka Racman |
attached are new LTspice versions of both UcD and LeapFrog ampliverter. Compared to the first version there are some improvements:
-differential construction like the real UcD
-startup is now reliable into any load from short to open with any offset voltage present at the input
-logic elements have been changed to reflect real components that will be used in the real design (74xx74 Dflipflop, 74xx02 NOR, 74xx86 XOR and ISL6207 gate driver)
-simulates faster
Best regards,
Jaka Racman |
| subwo1 |
| Hi Jaka, just about all I can say right now is that it looks awesome.:cool: |
| Jaka Racman |
attached is first revision of UcD type ampliverter schematic. I started with UcD type since I suspect it will be a little easier to debug than the leapfrog version. PCB is not yet finished. Here are some comments:
-primary (mains) part of the ampliverter is denoted by the light brown polygon. It should work independently of the secondary section and provide auxiliary supply voltages to the rest of the circuit. IC1 forms startup oscillator that works untill UcD modulator kicks in. It's oscillation frequency is set below lowest expected UcD modulation frequency under normal operating conditions.
-secondary part starts with a copy of the UcD modulator (from the published papers) comprising IC101 and IC102. Comparator IC102 should be LM361 or discrete design because of the rather high common mode signal at the input. Modulator's output is ORed with current limiting comparators IC104 and fed to both primary and secondary switching stage through toggle flipflops IC109.
-isolation of logic signals between the primary and the secondary circuit is achieved by HCPL-7723 optocouplers. This is potentially the weakest part of the circuit. Chosen optocouplers are pretty fast (16ns propagation delay and 1ns pulse width distortion typical), but if anyone knows a better alternative I would be grateful.
-both the primary and the secondary Mosfet drivers are transformer coupled, since under normal operating conditions both work with approx 50% duty cycle. Modulation is achieved by phase difference between the primary and the secondary, not PWM.
-main isolation transformer is divided into three identical transformers T1,T2,T3. This allows 1 to 1 turns ratio and reduction of the leakage inductance. Current sharing is automatic because of the series connected primaries. This also allows three sets of bidirectional connected Mosfets which switch only 1/3 of the total output current. Hopefully SO-8 devices will be used because of that.
Best regards,
Jaka Racman |
| classd4sure |
| Nice work Jaka, look forward to test results . |
| subwo1 |
| The phase shift modulation seems like an especially nice touch. |
| analogspiceman |
| quote: | Originally posted by Jaka Racman
-secondary part starts with a copy of the UcD modulator (from the published papers) comprising IC101 and IC102. Comparator IC102 should be LM361 or discrete design because of the rather high common mode signal at the input. Modulator's output is ORed with current limiting comparators IC104 and fed to both primary and secondary switching stage through toggle flipflops IC109. |
Digitally ORing together the voltage and current loops seems to avoid the usual mode-crossover problems that stem from excess charge accumulating on the inactive loop's compensation capacitor.
| quote: |
-isolation of logic signals between the primary and the secondary circuit is achieved by HCPL-7723 optocouplers. This is potentially the weakest part of the circuit. Chosen optocouplers are pretty fast (16ns propagation delay and 1ns pulse width distortion typical), but if anyone knows a better alternative I would be grateful. |
A self oscillating amplifier requires a stable, controlled rate of change of phase to achieve controlled instability. Delay, if repeatable and not too large (like your 16ns optocoupler delay), can contribute nicely to this design function. Unless you know of another reason to further reduce this small delay, I wouldn't worry about it.
| quote: |
-both the primary and the secondary Mosfet drivers are transformer coupled, since under normal operating conditions both work with approx 50% duty cycle. Modulation is achieved by phase difference between the primary and the secondary, not PWM. |
Always assume the worst sort of input signal will eventually appear. Imagine the largest possible input that is the highest possible subharmonic of the switching frequency. This type of input could drive the duty cycle to stray well away from fifty percent, leading a design that appears okay under normal audio full loading to fail due to transformer saturation.
| quote: |
-main isolation transformer is divided into three identical transformers T1, T2, T3. This allows 1 to 1 turns ratio and reduction of the leakage inductance. Current sharing is automatic because of the series connected primaries. This also allows three sets of bidirectional connected Mosfets which switch only 1/3 of the total output current. Hopefully SO-8 devices will be used because of that. |
You are right that the transformer primaries must share the same current, but what ensures that they share the same voltage? Depending on the size of the interwinding capacitance, things might get especially dicey during the switching edges since the top transformer will be subjected to a three times greater voltage change.
However, my greatest concern with this design is that there is no provision for catching the current from the transformer leakage and output inductances during the inevitable on/off timing errors with the bilateral output switches. A friend of mine once built a working high power prototype ampliverter style sine wave power inverter. He found that the only practical solution to this problem was to clamp the troublesome nodes to catch capacitors (plus and minus) on the outputs and use small auxiliary power converter(s) to return the power to the input bus.
| Jaka Racman |
Hi analogspiceman,
thank you for your constructive comments. I will try to answer some of your remarks.
Regarding optocoupler, I am worried much more about possible jitter and asymmetric delay (between the primary and the secondary part) than about the absolute delay number.
I have observed driver transformer waveforms in simulation under what I thought would be a worst case scenario (square wave input driving amplifier into clipping). I thought that both the current and the voltage waveform were acceptable. I will try the test again with your recommendation.
Yes, transformers. I hope that in the end that will not be the end of the whole project. Normal SMPS transformers are useless for this application. But I have measured some bifilar wound toroids, and I can achieve leakage inductance around 50nH. Another field of opportunity is use of ideas presented by Edward Herbert in matrix transformers and coaxial transformers . Lastly, I have an old Motorola RF handbook. In the past I have sucesfully used some construction tips for RF broadband transformers in 6kW continious, 20kW peak transformer for resonant capacitor charger.
Those RC snubbers across the secondaries in the published schematic are only a reminder that probably something more serious will be required at the end. But thank you for reminding me that i should finish the transformer before i proceed with the PCB. I guess I was a little overwhelmed with the whole idea.
Catching freewheling current of output inductors will be another challenge. That's why 30mOhm Mosfets are used as drivers and transformer coupling is used. I want to minimize the dead time as much as possible.
Thanks again for comments and
best regards,
Jaka Racman |
| analogspiceman |
Hi analogspiceman,
| No problem. There are precious few of we analog/SMPS designer types around who are also interested in class d amplifier design. I am vicariously enjoying immensely your pushing the design frontiers with your ampliverter work. If I weren't so busy with paid work, I'd love to make up a schematic and layout of a SMPS/leapfrog amp combo for the DIY community. Class d technology is such an elegant symphony of such a variety of skills, it's too cool not to share.
| quote: |
| Bear in mind, I am not implying that a problem necessarily exists, just that it behooves you to check the design under worst case drive conditions, i.e. as close as it can get to unipolar drive (most likely to lead to dc offsets, transformer saturation and other nasty explosive problems).
| quote: |
Yes, transformers. I hope that in the end that will not be the end of the whole project. Normal SMPS transformers are useless for this application. But I have measured some bifilar wound toroids, and I can achieve leakage inductance around 50nH. Another field of opportunity is use of ideas presented by Edward Herbert in matrix transformers and coaxial transformers . Lastly, I have an old Motorola RF handbook. In the past I have successfully used some construction tips for RF broadband transformers in 6kW continuous, 20kW peak transformer for resonant capacitor charger.
| Low interwinding leakage is good, but it invariably comes at the cost of higher interwinding capacitance. Sometimes (usually at high voltages) capacitive losses can end up exceeding inductive losses when leakage inductance is minimized (the tradeoff goes as the fourth power of leakage). The top transformer will "see" three times the voltage swing between windings as will the bottom transformer. At a minimum, this will skew voltage balance during the switching transitions. The only way to ensure strict voltage balance is to put the secondaries in parallel (however, I don't know that perfect balance is best). You might consider putting small, tightly coupled common chokes in series with each transformer primary if capacitive imbalance turns out to be a problem.
| quote: |
Catching freewheeling current of output inductors will be another challenge. That's why 30mOhm Mosfets are used as drivers and transformer coupling is used. I want to minimize the dead time as much as possible.
| As well you should, but don't expect to be able to reach perfect switch timing with no glitches. If you don't catch the energy stemming from timing errors it will most likely end up avalanching the output MOSFETs. Are you sure they can take it?
| Jaka Racman |
Hi analogspiceman,
just a quick answer. I intend to cope with interwinding capacitance problem in another way. I will use three separate cores for the secondary winding, but primary winding will be common for all three cores. So actually I will not use three but only a single magnetic structure. First try will be three toroids with single layer bifilar secondary winding stacked on top of each other. Primary will then be wound over all thre cores. Kind of a matrix transformer if you like. Another possible solution is use of coaxial transformers, where one half of the secondary sees half bridge capacitive divider node and another half of the secondary sees switching node.
You are probably right about avalanching also. But since this first design will be near UcD400 characteristics, peak currents in inductors will be around 7-8A. So maybe I will get around that unpunished for the first try, but on the long run catch diodes will be probably necessary.
Best regards,
Jaka Racman |
| mzzj |
Hi analogspiceman,
Best regards,
Jaka Racman |
Definetely intresting project that you have! :up: And thanks for the links. I just "invented" similar toroid transformer structure some time ago but wasnt any sure about useability :) |
