diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Mullards branded as Telefunkens??? - Click HERE for Original Thread
safetyman
Does anyone know for a fact that Mullards did or did not manufacture for Telefunken? The reason for asking is coz I bought a pair of Telefunken 12AX7 which had no <> at the bottom, but the letterings were partially smeared off. The seller told me that these were Mullard made Telefunkens. Is this a fact???
Colt45
quite possible.
look for the acid etch code on it to see where it was made
safetyman
Maybe someone can help me with the codes. The markings on 1 tube is I63 and underneath that are the letters B8A4 and on the other tube is I63 and B7L3.
Could someone please assist or point me to any good resources for me to research the date codes?
Colt45
http://www.triodeel.com/images/philipstubecodes.pdf
safetyman
Colt, thanks. That is a very helpful guide.
316a
quote:
I63 and B7L3
Blackburn 1967 or 1977 , 'shortplate' version ECC83 with nickel grid posts
cheers
316a
amperex
Yes, Mullard manu for Telefunken. No triangle at bottom of glass means not a true Telefunken W. German manufactured tube.
safetyman
Thanks 316a and Amperex. I came to the above conclusion after researching the pdf file link that Colt gave. I am learning about tubes and how to decipher them. Very interesting.
Page generated in 0.025053024291992 seconds with 17 queries,
spending 0.00944972 doing MySQL queries and 0.01560330 doing PHP things.
