| sumacSK |
I know it is not completly single driver, but still single point source... ;) I'm considering buing this driver and use it on open baffle (or maybe closed) with subwoofer. I'm wondering if there is someone who has some experiences with this driver. Any crossover suggestions? (I have some crossover scheme from german magazine, but it is for beyma 8DX... :cannotbe: ) I know that the best way would be active crossover (like behringer DCX) but I'm affrraid that my budget don't allouds me buying it... My room is about 25 m2, musical tastes: everything.
Sorry for my bad english :confused:
Thanks Martin |
| knorke |
| I used years ago the predecessor of the 8bx (which had a paper cone) in a closed box (around 20l) with good results. It had strong bass output so you might not need necessarily a subwoofer in your room. |
| Jimmy154 |
| Haha, I knew the day would come when I would see a Slovak on here :D |
| soongsc |
| quote: | Originally posted by Jimmy154
Prague is not in Solvakia. I'm confused.
:confused: |
| DarkOne |
He is not alone here. Here are few Slovaks on forums for a long time. |
| sumacSK |
Yes there are more slovaks here... But back to speakers... So nobody with experiences with 8BX???????
Martin |
| Jimmy154 |
| quote: | Originally posted by soongsc
Prague is not in Slovakia. I'm confused.
:confused: |
He has Slovakian flag. Lot of Slovaks go to Prague to work and/or study, like my parents when they were young studied there. They want me to go study there too, but I'm too smart already :D
I know nothing about speakers, sorry :xeye: |
| belin |
I have a pair of those that i intend to use like surround channels in HT. I haven't measured it yet, maybe this weekend. they are in a proto baffle with a size appropriate for my wife, so is not big in excess.
Sorry for my pathetic english. |
| sumacSK |
Hi belin,
Thanks for the response! So you are using that speakers on open baffle? What size? What kind of crossover do you use? And most important: how do they sound? :bigeyes:
Thans a lot Martin |
| belin |
Hi SamacSK,
I'm sorry, but i couldn't do the acoustic measures of the drivers. The power supply of my computer chose to broke this saturday, carrying with him the motherboard. Maybe you can use the T-S parameters that I measured time before. Here they are:
fs 47 Hz
Qes 0.590
Qms 6.8
Qts 0.543
Vas 36l
Re 5.5 Ohm
Le 0.05
Sd 216 cm2
(from the manufacturer)
Xmax 5mm
Pe 100w
The crossover will come next to the acoustic measurements, for now I use foobar for equalization porpouses. I have to say that I'm not really good optimizing the system by ear, and the sound I obtained is not great at all. I'll try to put photos later on the week.
Sorry again, maybe in a few days...:xeye: |
| sumacSK |
Hi belin,
Thanks for information. I'm looking forward to see measurements and crossover scheme. BTW I have some crossover scheme from german magazine, so if you want I can send you...
Martin |
| soongsc |
| quote: | Originally posted by sumacSK
Hi belin,
Martin |
Pardon me,
but how do you plan to us crossovers on a full range speaker? |
| Variac |
| From the first post, I suspect it is a coaxial speaker, with a separate tweeter. |
| soongsc |
| quote: | Originally posted by Variac
You're right. I don't think these could be use open baffle. Looks like an interesting project. |
| belin |
I'll be very pleased if you send me the scheme SumacSK, thanks :angel: . By the way, the power supply wil come in two days. I'll try to do the measurements as soon as possible.
I have to say that i don't pretend to go low nor loud with these, maybe just to 80 hz with a litle active help. The porpouse of the drivers in my case is for rear channel in ht. I modeled it with winISD Pro for closed and vented boxes, with Martin King's tools for TL and MLTL, and with Thorsten Loesch spreadsheet for dipole, but the real concern is that my wife don't want to see boxes near the sofa. If this wasn't the case, the closed box don't have a size that big if you can live with a no flat response, or a big MLTL for low end extension... (Be careful with my comments, i'm not and expert, nor i pretend to be, this is my second project, and my skills are not that great).
Soongsc, in http://profesional.beyma.com , inside the section dedicated for coaxial units, it's possible to get information about the driver. I think they are a little bit optimists (7Khz for the midbass unit i think is a little high), but you can get a reference. |
| soongsc |
| It would be nice to see some impedance plots and the FR phase plots. At first glance, it seems a XO around 4K~5K would be a good start. If you're not concerned about effeciency, series XO probably would be good for this application. |
| Variac |
| It couldn't hurt to contact Beyma and ask if they have a recommended crossover for that Coax |
| belin |
I take some photos of the beymas in the proto baffle yesterday.
Here is the front of the baffle. (32 cm wide, 55 cm high, 10 cm each wing). The driver is about 72 cm above the floor, which give a null about 700 hz in Thorsten's dipole spreadsheet, and the size make a high pass of 6db/oct with a -3db point near the 210 hz, with a +3 db plateau from 250 hz up to 1200 hz.
I don't have the power supply yet, so i can't measure the response nor i can correlate the calculations with the reality, sorry... :bawling: |
| belin |
| In the position where i pretend to measure. The room is a little small, but i have one meter and something to all sides from the driver (two and something to the front wall with the curtains), and the same can be applyed to the microphone position. |
| Paul Ebert |
Were you ever able to get measurements? If so, I'd be interested in what you found.
Paul Ebert |
| sumacSK |
Belin have send me the graphs, so I'll post it here.... Black curve is on axis, red is 10º out of axis, green 20º out of axis, blue is aproximately 30º out of axis, The second black in the upper graph is the response
with more than 45º out of axis. |
| sumacSK |
Here is crossover scheme...
In the upper graph (of freqv. response) 10uF capacitor is changed with one of 15uF.
Martin |
| Gregory Isaacs |
they look interesting - how do they sound? |
| belin |
Hi all,
I'm working (I must say not much) with new measurements. The time window is now reduced to 2.5 ms aprox. The project is going really slow, but I don't have enaugh time to spend in hobbies. I'll post the graphs of the tweeter and woofer responses in next messages. |
| belin |
| Tweter responses (0º/45º) |
| belin |
| A new crossover that I'm simulating. |
| belin |
| The simulated response (SpeakerWorkshop) of the crossover. |
| sumacSK |
Hi Belin!
How is your project?? Some new findings? I'm still deciding whether use this driver in my next project or not... :hot:
Martin |
| v-bro |
Hi guys!
I've been asked to build a filter for this driver by a friend of mine.
Any news on this project?
How did that filter indeed turn out Belin?
And what did you do with the drivers in the meantime SumacSK? |
| Natali |
Hi, I just finished a pair of bass reflex boxes (60lt) and I am currently using this crossover
Suggestions?
Thank you, Andrea |
| v-bro |
how's the sound?
Can you show pictures?
Did you measure the response? |
| Natali |
Yesterday evening we made some listening test with a friend and they are not bad at all. Maybe it is better to increase the first capacitor 2,2uF to 2,6-2,8uf (it seems to be better).
I have also changed the resistor (in parallel with the tweeter) from 1,8ohm to 3,3ohm, but in this case there is no audible difference.
You can see the speakers here: http://www.audiofaidate.it/forum/to...p?TOPIC_ID=2819
When we will measure the response, I will post the results.
Ciao, Andrea |
| v-bro |
| Hey, cool thanks for that! :cool: |
| sumacSK |
I never managed to buy them.. I ordered them but then they told me that this speaker is out of production.. I don't know.. :(
Natali: that speaker looks good.. |
