| Jonasz |
Hi!
I was thinking about using UcD180 for the range
100hz-1500hz in a fully active system using two
parallell Seas W22EX. http://www.seas.no/PDF%20data%20exc...2EX001E0022.pdf
The impedance curve indicates that the total
impedance will be around 3 ohms. My question
is, will the UcD180 maintain sound quality under
these terms without "loosing grip" of the cones?
The supply voltage will be +-40V.
Jonas |
| Jan-Peter |
Jonas,
This is no problem. We test all UcD modules with a load of 1 ohm and the THD must be below 0.05%.
Jan-Peter |
| Jonasz |
Thanks Jan-Peter!
That's all I wanted to hear...:)
Jonas |
