diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
Super reg question -- on references - Click HERE for Original Thread
jackinnj
in an article appearing in the late 1990's a fellow ham radio op used multilple Thaler voltage references (don't worry, you won't be able to find them) to reduce the noise, tempco effects and improve acuracy. The result was a DIY voltage measurement unit which was approaching the acuracy of high end HP, Keithley and Fluke equipment.
how would this affect the "noise" of the Super-Reg if one were to combine multiple references, RC filtering with an ultra-low noise error amp (like the AD797)?
peranders
Just wondering but how much noise did this super reference produce really? A LM329/LM199 and LTZ1077(?) are all pretty good and a plain LM431 with the normal heavy LP-filter will also be rather low noise-ish.
ADR420 is pretty good also from Analog Devices.
http://www.diyaudio.com/forums/show...9863#post639863
jackinnj
they have references with 1, 3 and 6uV LF noise -- of course you have to look at the tempco stats etc. . They are available in K and H grades.
Page generated in 0.017362117767334 seconds with 17 queries,
spending 0.00663996 doing MySQL queries and 0.01072216 doing PHP things.
