diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
PassLabs Pre-Amp transistors Volume ? - Click HERE for Original Thread
jleaman
I've been looking and i see a few products now with a digital volume pots and stuff. I'm wondering how they do it.. i can see from pictures they use surface mount transisters one transistor per step with a resistor to change the volume out put. Does any one know how this could be done. Maybe with a rotoray control of some how ect ect. to turn on each transistor. Id like to try and build one.. So far i have seen the pass labs pre-amp and the conrad johnson pre-amp's and a few others.. Any one got any idea's. ? I don't want to step on any toes but it would be a good project and be able to hear silence when turning up the volume instead of relay's..
jleaman
Quote from a friend..
it's "just" a ladder of resistors, you change the "bottom" resistor in the ladder by turning on or off a transistor in series or parallel with a resistor..... simple system really - in theory.... the problem is getting it to work without noise from the switching..and getting rid of the noise from all the large resistors... you should go SMT IMHO to minimize the size of the thing
analog_sa
Why large resistors? I find it difficult to believe that a bipolar transistor switch can sound better than relays although it's obviously much cheaper.
jleaman
quote:
Then why does pass labs do it ? and ill use smd resistors..
analog_sa
Lower cost? Absence of annoying clicks?
metalman
Have a look at http://electronics.dantimax.dk/
jleaman
quote:
I don't want that..
Nelson Pass
Well, there's a trick to getting the low distortion and noise
from such a technique, but currently it resides under trade
secret, until the patent office sees the light.
jleaman
I guess ill have to wait ? I dont want to patent any thing i just want to build it and learn :D
What do you think of this type of circuit nelson. What would you prefure a pre amp with all them transisters or a nice alps / DACT pot ?
jleaman
Ok I found it. Id like to build this.. SMD i know what the small signal transistors are but i dont know what the digital ic is to turn each transistor on one at a time..
analog_sa
Any microcontroller with enough i/o pins will do. A 90S8515 off the top of my head will be fine.
Nelson Pass
quote:
The pot has its own problems, of course. When we used relays
we got a lot of whining about relays clicking. The solid state
solutions that existed sucked (and still do), but Wayne developed
a circuit that had about 1/10 the noise and distortion and could
handle about 10 times the voltage, so we used it. No complaints
about sound, although there is still a slight "zipper" noise as you
spin the volume control.
jleaman
Ive got the "schematic" i'm working on it right now.. Just need help now to desifer the chip that turn's each transistor on one at a time. I presume the Voltage ? audio signal goes through this chip and is then gone through a ladder resistor then to the output.
The reason i wanted to build this was to A gain experiance in SMD part's and more eagle board layout time. B to build my OWN pre-amp board's..
Nelson Pass
The chip is a digital latch, and does not see analog signal.
jleaman
ok... Nelson May i email you personally please..?
J'
wayne325
I'm right now doing the same thing you're talking about.
I'm going to use a PIC16F684 I think as the controller.
You can get a kit from Microchip called the "PICkit1" Flash
Starter Kit. It's $35 from Digikey or Mouser in the US.
The kit has software to program the part, I think the part
has enough program memory to do what you want to do.
THere is a programmer in the kit too so you would have
everything you need to make the controller with the PICkit1.
I'm going to go the relay route because I believe it to be
lower noise than transistors and it's simple enough to implement.
Clicking noises when changing volume wont bother me.
I'm going to use encoders for the volume and balance and
selector inputs - that's 6 which will use up port A of the PIC.
The PIC only needs 3 outputs to drive 74HC595 shift register
with parallel load. I'll use a 12V supply for the relays and use
VN2222LL n-channel FETS to switch the relay coil current.
I will use TQ2-12V relays and metal film resistors.
That's the plan. I haven't tested it yet and I haven't started
programming the PIC yet either but I do have the kit and
if you're a programmer it will be very easy for you to program
it. It took me about 2 hours to go thru the part manual to
figure out the 16F684. If I had a hex file I'd just mail it to
you.....
Anyone have any input on my choice of parts and the overall
plan ?
W.
jleaman
you.....
plan ?
W.
Well i do have the schematic for how it all exactly should be.. Me i don't want to use relays. they draw to much current there slow and they make to much noise.. That is why im going the surfact mound transistor way.. Email me and we can talk more..
rsbay
I use an Atmel AT89C51RC2 with a 10 Bit relay volume control in my
Aleph P preamp (not yet finished). Have a look at my homepage
http://www.r-stens.de/diy/AlephP/diy_aleph_p.php
Sorry, up to now it's only available in German language, but you can
have a look at the schematics and photo's.
I use a I2C bus with the PCF8574 I/O port and ULN2803A as the power
drivers for the relay's.
Ralph
RCBandwidth
Jleaman:Here's a link to an alternate way of volume control-a voltage controlled amplifier from Analog Devices.
http://www.analog.com/UploadedFiles...7SSM2018T_b.pdf
You can also check out some of their Digital Pots,If you want to experiment you could use a "Basic Stamp"microcontroller with built in I2c support..A few of the Digital Pots from Analog Devices have the I2c interface..Bob C.
Nelson Pass
Why not, everybody else does. :cool:
RCBandwidth
Jleaman:Yet another interesting chip from Analog Devices..
http://www.analog.com/UploadedFiles...3786ssm2164.pdf
wwongchan
How about CS3310 .I found this chip in JEFF Rowland Concerto preamp.
digi01
Hi Jason,
I have try to reply you via yahoo&office mail but all failures :"(
however I can receive your mail:rolleyes:
Z.
jleaman
quote:
Originally posted by digi01
Hi Jason,
Z.
are ya talkign to me or some one else..
if it doesnt work post here and ill provide a email address..
digi01
Yeah,talk with you.I have a gift to you.
Z.
jleaman
Z.
I just pm'd yo with 2 email addys...
J'
Konsti
I discovered this thread and I really like the idea replacing the bunch of relays by a couple of SMD bipolar transistors. I trust NP fully they are not worse than the relay solution. Are there any news on the details of implementation or is there still much IP and secret construction in?
@jleaman:
I can't find a way to contact you directly, so if there are any news or ideas to implement this I really appreciate your help :-)
Kind regards, Konsti
Page generated in 0.073843955993652 seconds with 17 queries,
spending 0.01245880 doing MySQL queries and 0.06138515 doing PHP things.
Please support our sponsor.
