diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
white noise in subwoofer, home system - Click HERE for Original Thread
lucksi
Hello,
I have white noise comming from my subwoofer and my bodyshakers. And not just barely audible either...
This started when I build in two bodyshakers with a new amp into my existing system. Somehow, if both the subwoofer and the amp with the bodyshakers are connected, they donīt like each other and it seems like there are stray signals.
The sub and the amp have seperate audio lines and my main amp/decoder even has two subwoofer exits, so they are not using the same either.
I even tried a new cable which doesnīt run next to the sub in the wall (lies across the room atm) but to no avail...
So I am pretty much stumped as to what is causing this or how to get rid of it. Without throwing the bodyshakers out of course. The amzing thing is that I could build a completely new system for my car just fine...
Any help or suggestions would be appreciated.
And if you need more info, like modeltypes of subwoofer and amps, just holler. I didnīt post them since they seemed unrelated to this problem, but then again, Iīm no expert in those matters.
Page generated in 0.019011974334717 seconds with 16 queries,
spending 0.00949311 doing MySQL queries and 0.00951886 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
