diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Reducing Audio Line Output? - Click HERE for Original Thread
freezz
Hi All,
I have a Stereo preamp mixer which has a Line Output and is feeding into a Power Amp.
Can I somehow reduce the Audio Line output amplitude on the mixer using some sort of a attenuator, or perhaps inline resistors?
I'm finding that I have to have the amp volume controls very very low and still finding that my mixer output volume is set to half.
What I would like is to use my mixer volume controls to the fullest and not have the sound so load, but to do this I have to turn the amp to about one notch. What could be wrong?
PLEASE HELP!
Any suggestions would be appreciated
Freezz
rflachs@netspace.net.au
janneman
quote:
Originally posted by freezz
Hi All,
PLEASE HELP!
Freezz
This is a bit unusual. Could it be that the preamp/mixer has both an unattenuated line output as well as a volume controlled line output or preamp output, that you are not using? Do you have a pic of the backside/plug field?
Edit: I think I misread your post. Forget my reply.
Jan Didden
moamps
If you connected the mixer to a professional PA amplifier, the levels would be OK. But, if you connect the mixer to a home amplifier then the overall sistem gain will be too high. The simplest method to reduce the gain is inserting an L-pad resistive network (for example 10k/1K inside a cinch connector).
Milan
freezz
Hi Milan and thankyou for answering my thread.
Just letting you know it is connected to a Pro Amp, all used for entertainment (DJ Gear) and not a home amp.
I did look up the L-Pad as you've recommended, can I just put one resistor in series to each channel on the outputs? Will that effect the quality or anything else? The reason I'm asking because I would like to keep it plain and simple without inserting a sub PCB
Due to it being low signal I guess I would'nt need to use anything bigger than a quarter watt resistor? is this correct?
Once again many thanks
Freezz
quote:
Milan
moamps
you need two resistors.
Look at the picture below (20dB pads).
All resistors are 1/4W.
Milan
Enzo
The power amp has no level controls of its own?
ctardi
If I were to want to do the same thing with a TRS Plug, would 2 resistors mid line work? I am having a bit of trouble understanding your diagram.
imix500
If you want to use TRS, just wire it up as pin 2- tip, pin 3- ring, and pin 1- sleeve. It will work the same.
freezz
Hi Milan and thanks for the reply
This may sound stupid but why 2 resistors? Why not just have 1 resistor per output inline on the output connectors.
Many Thanks
Freezz
Milan
moamps
Amplifiers usually have 47kohm input impedance. To get 20dB attenuation with this impedance, the series resistor shoud be around 470kohm. This is the high impedance Lpad which is prone to EMI's and may inject noise, linear amplitude and phase distortion into the system. (in a nutshell)
Milan
rabbitz
freezz
Read this on voltage dividers.... it's good stuff.
http://sound.westhost.com/vda.htm
You can buy some Rothwell in line attenuators which do about 10dB.
http://www.rothwellaudioproducts.co...ttenuators.html
freezz
Hi Enzo
Yes the amp does have volume controls, but I'm finding that I have to have them turned down to about the first indicator (Notch) so I can't turn the controls half way up, because it would then make me turn the volume controls on the mixer down low.
Freezz
QUOTE]Originally posted by Enzo
The power amp has no level controls of its own? [/QUOTE]
keyser
you could also look at your local car-hifi store. They should all kinds of line-attenuators for little money.
Page generated in 0.042227983474731 seconds with 17 queries,
spending 0.00885296 doing MySQL queries and 0.03337502 doing PHP things.
