diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
How to get +15v and -15v from 12vdc - Click HERE for Original Thread
mbcouple
I have a 12vdc source that fluctuates, and i need a clean +/-15v dc power supply from it. Does anyone have any ideas?
Hans
imix500
How much current? Maybe a dc-dc convertor?
mbcouple
Sorry, good point. I dont need very much current. Less than an amp, maybe between 250 and 500mA, more is ok though. I am looking for something i can build, instead of an off the shelf product. I am hoping to keep the cost of the circuit beloew $30 if i can.
Hans
richie00boy
You're looking at a DC-DC converter and you'll need a transformer. I'll be putting a simple design on my website soon, but you need to be able to wind your own little transformer. I'm thinking of getting some made up if there is enough demand.
imix500
Like this?
http://www.jameco.com/webapp/wcs/st...roductId=217111
richie00boy
That looks like a good solution.
pinkmouse
For $30, surely it would be easier just to build a proper one from scratch?
Mike Gergen
Go to the national Semi web site. You put in the requirements and the site designs the supply you need.
DigitalJunkie
Maybe something like:
http://www.users.qwest.net/~ptaylor...-Neg-supply.jpg
It's a small dc-dc from older Fluke DMM's.
The input is +5V and the output is +/- 15V (theres a 78/7915,thats not in the schematic,along with the + output diodes,and filtering caps.I modified one a bit for another project-only needed a Neg output.)
I'm not sure of the current available,but it's pretty decent.. Maybe 500ma?
richie00boy
quote:
US$30 is around £16.50, consider that you have to source a transformer or parts then wind your own, I think that's cheap not to mention a compact solution. A custom transformer will be easily £15 on it's own.
pinkmouse
Not in the states, dollar and pound prices are just about equivalent, so 30$ will buy about the same as £30 over here.
So how much are those dc-dc converters to do 500mA anyway.
paulb
Somebody suggested National. Here's a schematic from their LM2585 datasheet. Looks like the transformer may be available from Coilcraft.
A word of warning: switching power supplies are notorious for being difficult to build. Chances are you'll probably face a few problems while building.
jacco vermeulen
is a voltage doubler followed by a voltage regulator not easier ?
richie00boy
Check your facts ;) I did with today's exchange rate before I made that post. US$30 = £16.44 if you want to be picky :D
pinkmouse
Richie, you misunderstand. An item that costs £30 in the UK will usually cost around 30$ in the US.
paulb
quote:
Not for that much current (0.25+ amp).
Yup, dollars for pounds. Also works in Canada.
Page generated in 0.040469884872437 seconds with 17 queries,
spending 0.00828600 doing MySQL queries and 0.03218389 doing PHP things.
Please support our sponsor.
