| First Gainclone - Help with Parts List - Click HERE for Original Thread |
| ScottRHinson |
It doesn't look like the binding posts would be insulated from the chassis....which might be an issue if it's a metal chassis.
Scott |
| homer09 |
your fuses are not compatible with your IEC socket. you need 5x20mm fuses for that socket, not 1-1/4" x 1/4".
start thinking about chasis = hardest part!
is this a true amp, or integrated? if you have two pairs of RCA's, you need a method of switching inputs. |
| schmalex |
Thanks for pointing out some of my minor league errors. My plans are for a NON-integrated amp - the 2 pairs of RCAs was a typo. I also hadn't thought of the need for -insulated- binding posts.
Can anyone comment on the toroidal transformer? Is this the right one? Apex jr. has some much less expensive versions, but I don't know if they will work well.
As for the chassis, I've got some ideas. There's a plastics dealer down the street from me. "Have you considere a future career in plastics?" I'm thinking about picking up some of their scraps and making an acrylic Patek, with a metallized interior for shielding. Haven't quite figured that out yet. And where can I get a solid copper bar out of a trash can...
Thanks |
| chipco3434 |
| That tranny will work fine. For a little more umph you could go to the Avel 330VA 2x25v. Five mo' dolla's. |
| Kofi Annan |
| quote: | Originally posted by chipco3434
Five mo' dolla's. |
Not to be a stickler on the spzellin', but it should be dollaz.
Kzofi |
| chipco3434 |
| I meant dollaz. |
