diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
off-topic how does electric air freshener work? - Click HERE for Original Thread
darkfenriz
Anybody knows?
I mean simple cheap one made as a 'big plug'.
thanks
Cal Weldon
AFAIK it's just a little heater, and in some a fan, to warm the freshening agent and wear it out sooner. They last longer if you don't plug them in ;)
Cal
Dr. Photon
I have also seen some cheap inonizers that are essentially a high voltage, miniscule current DC power supply. This is applied to needs olr plates or whatever. Line operated units typically used diode/capacitor "ladder" multipliers. I have a cheap unit in my car that is essentially the guts of a CCFL inverter with a cap and diode on the output. This voltage was applied to a mesh wrapped around the outside of a small NE-2 sized blue neon bulb, which had it's leads grounded. It emits a small amount of Ozone, and it manages to remove the stale smelling "Caravan Musk" without adding any "canned new car scent". And the Blue light adds 5 horsepower! ;) It does provide for interesting conversations with passengers on just how useless it is.
Page generated in 0.020087957382202 seconds with 16 queries,
spending 0.00928473 doing MySQL queries and 0.01080322 doing PHP things.
Please support our sponsor.
