diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
OPA549 on single supply - Click HERE for Original Thread
bostjancek
Hello !
Can anybody comment if the schematic for connecting the OPA549 on the single supply is correct ? If it is not please give me some advice how to make it right.
Cheers
SSassen
There's a few errors, look at your power supply connections. But more importantly why would you want to run with a single rail? You now have to use a coupling cap at both the input and output which isn't what I'd recommend for anything related to hifi. If you only have a 30-volts single rail you can also split it to 2x15 and settle on that.
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
bostjancek
I have to put this amp in an guitar amp where I have only +30V DC. Can you tell me where are the errors at the power suply connection ?
Cheers
mod_evil
When do you not have a negative supply. The V- conector go to GROUND. ;)
carlosfm
Hi bostjancek,
Yes, there are a few errors on your shematic.
The 4,700uf + 100nf caps are in series with the positive voltage rail (?!), they should be parallel from V+ to ground.
The input 2.2uf cap should be before the 47k cap.
And a suggestion: use a 4,700uf cap on the output, although not so important for a guitar amp.
mod_evil
quote:
Originally posted by carlosfm
Hi bostjancek,
And... use a snuberized PSU :D ... I like the snubber that sound is more beautiful than the others schematics! I love your idea.
Thanks :bawling:
carlosfm
quote:
You said that, not me. :D
carlmart
quote:
One suggestion:
Try a different way for your virtual ground input connection. Increase the value of those resistors to something like 47K each, and don't connect that point directly to the + input, but through another 47K resistor. Then use a a 1uF capacitor from that middle resistor point to the V- rail. That should lower your ripple noise. Or use the parts used in the LM3886 datasheet for single supply application.
A single supply design has several flaws, the large output capacitor being the main one. So I don't think it will help much using a snubberized supply with it.
Carlos
bostjancek
Thanks for your comments. I realy don't know where my head was when I drown the given schematic.
Cheers !
Page generated in 0.032233953475952 seconds with 17 queries,
spending 0.00887346 doing MySQL queries and 0.02336049 doing PHP things.
Please support our sponsor.
