diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Adding SPICE definitions to Microcap demo - Click HERE for Original Thread
antomas
Hi everybody!
I'd like to add this SPICE definition of a 2sK170 JFet to Microcap Demo. I fiddled for a while with the component editor, but I couldn't find the way. Is there any Microcap expert willing to help?
Thanks very much in the anticipation,
Massimo
soongsc
Found another definition on the web.
.model J2sk170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 Betatce=-.5 Lambda=1.923m
+ Vto=-.5024 Vtotc=-2.5m Cgd=20p M=.3805 Pb=.4746 Fc=.5
+ Cgs=25.48p Isr=84.77p Nr=2 Is=8.477p N=1 Xti=3 Alpha=10u Vk=100
+ Kf=111.3E-18 Af=1)
I think you just create a separate model file, import it as a parts library, then add a symbol definition. Is that part of Microsim? Didn't know they were around anymore.
antomas
Hi soongsc,
thanks for your answer. I use (I'd like to use) Microcap, not Microsim. In case, would you please detail where to find the commands you mentioned, how to create a model file and so on?
Thanks very much,
Massimo
Netlist
Here's a guideline from MC6. Don't know if you can add models in the demo version though.
/Hugo :)
jackinnj
google "spice directives"
Page generated in 0.029216051101685 seconds with 17 queries,
spending 0.00995016 doing MySQL queries and 0.01926589 doing PHP things.
