diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Loudspeakers
Vintage Wharfedale drivers - Click HERE for Original Thread
argonrepublic
I just aquired some drivers. I am hoping I can use them to build nearfields. There are no #s on them
The woofers are 8" , paper with a cast aluminum basket. approx.2" vc
The tweeters are heavy steel with a purple pol ish dome wit a plastic cover. Apparently they were two way.
Can anybody recommend a sealed enclosure for these or lead me in the right direction for finding out best configuration.
Thanks a million
Cal Weldon
If you can post a pic or two, someone might be able to identify the drivers for you. Without knowing, it will be really tough to get the box right. Kind of a hit and miss thing. Did you happen to scoop the XO too?
Cal
Page generated in 0.015743017196655 seconds with 16 queries,
spending 0.00722361 doing MySQL queries and 0.00851941 doing PHP things.
