| needlz |
Hey All...
I just finished a GC w/ carlos's snubberized PS in a seperate enclosure using the V+, V-, Case ground, Board ground umbilical. The GC works great but there is a very strong grounding buzz once RCA inputs are plugged in (regardless of whether the other end is plugged into the pre-amp or not). Should the RCA jacks be isolated from the case (they are currently isolated). Is there anything else I should check?
thanks. |
| needlz |
| nevermind... it was my preamp acting up. i plugged in an ipod directly to it and it worked perfectly. sweet little rig she is. |
