diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
TLC271 replacement - Click HERE for Original Thread
aarsoe
Can anyone tell me what I need to do if I want to replace the TLC271 in this schematic with a opa627 instead? Dont have means to measure oscillation, so want to be absolutly sure before just replacing the opamp..
Netlist
aarsoe,
Isn't this opamp used to correct offset?
/Hugo :)
aarsoe
Netlist
Hummm - good point, so are you saying that replacing it will be worthless? (happen to have a the 627's in house anyway..)
you can find the entire circuit here:
http://quadfranco.iquebec.com/schemas/amp_606.gif
Netlist
To me this is DC correction so unless some brighter minds correct me, replacing this chip is useless soundwise.
/Hugo :)
Page generated in 0.20178699493408 seconds with 17 queries,
spending 0.16017509 doing MySQL queries and 0.04161191 doing PHP things.
