diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
2*1500W amp for sale - Click HERE for Original Thread
Pafi
It is a dual mono 3 level Class D power amp with 50 Hz toroidal transformators. Has simmetrical XLR inputs, it produces 1500 W unclipped sinus power at 2,66 ohm load impedance.
Amp:
full bridge, 8 pcs of FDP2552 in each chanel (150V 36mOhm), seperate common mode and differential mode output filter chokes (cold operation), overcurrent sensing depending on chip temperature (approx. 90 A at cold FETs, 60 A at 100 celsius chip), auto-reset with ~1s period. Max output voltage: Vdd-2V.
Bandwidth: 15Hz-30kHz (+0,5/-3dB), S/N aprox. 110 dB (based on hearing tests), distortion: tbd. Effective carrier freq: 370 kHz. Residual carrier: ~300 mVeff at no drive, ~1,5V at half drive.
Supply:
soft-start, 1 ohm primer impedance trafo with 2*46VAC (128VDC) output, summa 19000 uF 200 V Nippon Chemicon elkos.
+ small signal supplies stabilised, power on sequence ensured by logic.
Photos:
http://www.hszk.bme.hu/~sp215/PWM_2kW/front2.jpg
http://www.hszk.bme.hu/~sp215/PWM_2kW/inside.jpg
http://www.hszk.bme.hu/~sp215/PWM_2kW/LEDs.jpg
Output power and waveform:
http://www.hszk.bme.hu/~sp215/PWM_2kW/354.jpg
http://www.hszk.bme.hu/~sp215/PWM_2kW/350.jpg
Weight: 21 kg, height: 88 mm.
If you have comments, questions, price-advising, please write to spafi(at)aramszu.net!
Page generated in 0.02294397354126 seconds with 17 queries,
spending 0.00910759 doing MySQL queries and 0.01383638 doing PHP things.
