diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Not all old Apple are rotten! - Click HERE for Original Thread
jaudio
Here are some picture of 3 boards I pull from an old apple computer. The parts are well worth the buck I spent. here is a short list.
Heatsinks 4 1.5*.6*1.75
3 1 *.6*.75
1 2.5*.6*1.75
1 1 *.6*.75
(all heatsinks measured in inchs)
Caps 2 330 mfd 400v(lots of Elec. Cap)
various caps mpp,pp,pps,mkt,etc
Ac filter
relays
Bridge D5SB 60
Voltage reg. +/- 12volt
2 +8volt
Resistors .5 to 5 watts (many different values)
You might be able to make out some of the other parts
jaudio
another picture
jaudio
one more
Sch3mat1c
quote:
Heh, I've got a few of those boards (with the FBT and attached CRT neck-mounted board). Friend pulled 'em from dumpster-prone school excess. :)
TIm
jaudio
Do you have plans for them?
My plan is to use them on an amp with parallel el84. I would like change to push-pull. The boards have all the parts except for the output transformers.
Page generated in 0.022085905075073 seconds with 17 queries,
spending 0.00859213 doing MySQL queries and 0.01349378 doing PHP things.
