diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
lm3875 questions - Click HERE for Original Thread
jimbo1968
The datasheet say that there will be no power on/off transients or DC spikes. Can I trust this? eg if I use the chip to power an expensive tweeter in an active system?
One of the graphs on page 10 shows power of up to 75W into 8ohms with 40V supply. Tthe same THD+N spec as used in the performance section which is based on 35Vsupply and gives 56W.
So what is this region of greater than 35V supply? Is it not recommended, just for the brave ?
Nuuk
I can understand your aprehension about connecting up a tweeter (or woofer for that matter) directly to an amp. I always used speaker protection with my active speakers.
I can only report from my (long ) experiences with the LM3875 chip amps that there is NO noise whatsoever when powering up and only the very feintest of pops a few seconds after powering off.
Of course, if you use a pre-amp or buffer (or active crossovers!), they must be powered up a few seconds (longer in the case of a valve buffer) before powering up the LM3875. ;)
jimbo1968
quote:
Are you being serious? Oh well, something else to find room for.
Nuuk
This is all documented on Decibel Dungeon. ;)
jimbo1968
Give us a clue (which section of DD) ?
I'm guessing a relay on the supply rails?
Fortunately I do have space in the PS compartment to add more components.
Nuuk
I was referring to the mention of noise at the output of the amps if you turn on everything together. What I meant was that if you read the Gainclone pages on DD, you would already have been aware of that problem.
I am literally about to try a delay circuit for the pre-amp/buffers and will write it up on DD if and when it is working successfully. ;)
jimbo1968
Thinking about it, my old av amp very clearly waits 3 or 4 seconds before switching in the power amps.
Haven't noticed it with the new one, but that is probably just because it does it quietly or quicker.
Page generated in 0.024117946624756 seconds with 17 queries,
spending 0.00767541 doing MySQL queries and 0.01644254 doing PHP things.
