diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
milspec opamps - Click HERE for Original Thread
biovizier
I had a search on the forum but couldnt find anything much at all...
Has anyone compared commercial spec opamps with industrial, military and space spec opamps variants of the same type?
I know the a certain well regarded phono uses milspec and the designer seemed to think it improved matters. Another amp designer that uses ad843 uses the space variant in the premium amp?
Has anyone checked this out before I go and blow my cash?
sam9
The most common benefit of milspec or NASA flight certified components is to survive hostile environments. If your listening room resembles a hostile environment. perhaps there would be a benefit. Normally improved audio quaility is not high on their priority list. One well known exception is the AD797 which is supossed to have been developed for sonar applications.
biovizier
Thats what I thought - I used to work in military research doing space physics stuff. My understanding is that they are temp and radiation hardened. Does this equate to also working better at room temp as well?
I turn up the volume real loud so the environment is quite hostile ;)
Leolabs
I think there are differences between"external"hostile environment and"interna" hostile environment:D
DSP_Geek
quote:
Originally posted by sam9
The most common benefit of milspec or NASA flight certified components is to survive hostile environments. If your listening room resembles a hostile environment. [....contextectomy...]
Met my ex, have you?
Francois.
Vidalgo
Generally, mil-spec components are builded with tighter tolerances (both electrical parameters and mechanical dimensions); special selected case materials for withstand in a harsh environment / high/low temperatures, agressive chemicals etc. etc. They passes more control stages at building process. That establish a high reliability of mil devices.
I.e. military qualification is not related to top electrical parameters, but related to guaranteed parameters at all conditions.
So, we can find a very trivial devices like LM148 or 1N914 in a mil-spec form.
biovizier
Sure - and goes double for space spec. So unlikely to sound any better?
Page generated in 0.024180889129639 seconds with 17 queries,
spending 0.00837994 doing MySQL queries and 0.01580095 doing PHP things.
