diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Help with switch selection and wiring needed - Click HERE for Original Thread
Thunau
I posted this in the amp forum as well, but I'm not sure that's the appropriate forum for this question. So here it goes in the Parts discussion again:
Would some one help me select the appropriate switch and show me how to wire it, please? :confused:
Here is my situation:
I have designed a passive frequency shaping circuit for my AKG K-1000 headphones. It consists of a R/L low pass, zobel and an L-pad.
I would like to be able to simultaniously switch both resistors in the L-pad and the resistor in the R/L. I need at least 4 positions- all in stereo. The last position should allow me to bypass the R/L alltogether. I'm looking at 2W tops passing through the switch.
Can you think of such switch/wiring? Or should I think relays?
Thunau
Here is the schematic. I need to switch R1041, R1061 and R1071 simultaniously. In the last switch position I would like to bypass the Inductor and the R1041 altogether.
Page generated in 0.023389101028442 seconds with 17 queries,
spending 0.01041484 doing MySQL queries and 0.01297426 doing PHP things.
