| speekergeek |
Hi all, I have had an intermittent problem with my center channel on my sony reciever since about a year ago. I am a sony authorized servicer so i have the schematic. I don't have much audio experience, mostly video so i am fishing for help here. the center channel uses a STK-350-230 as a mono amp for the signal, where it gets split into 2 halves of a waveform and sent to a booster (MN2488+MP1620) circuit.
The problem i have is during loud passages (in the vocal range only i hae noticed) it sounds like it may be getting full saturation and full cutoff, like a harmonic buzz. I totally thought it was my speaker because it was a **** speaker. but now with new speakers it still does it. any help is appreciated, i may be able to send you a page from the service manual to help nless you got it already.
thnx, mike |
| Netlist |
Mike,
Try replacing the STK.
The problem is that the output transistors are incorrectly biased.
Let us know if it solved the problem.
/Hugo :) |
