diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
****Silver wire 4n 99.99% 0.5mm x 25m for sale **** - Click HERE for Original Thread
zanash
Due to a miscalculation on the part of my supplier they sent me 10x my order........but of course charged me. So I have a number of rolls of Silver wire 4n 99.99% 0.5mm dia x 25m, each is 50g, for sale. I have used this for IC's and speaker cable. This is uninsulated, but ptfe sleeve works a treat
pm me
zanash
or email me !!!
zanash
I can't believe ....no one is intrested at a £1 / m ?
zanash
Thanks everyone who emailed me ........
I've sold them all now but if people want any I'm prepared to order ...email for a price.
njembrih
Do you have any pics of wire ?? This is for audio or voltage ??
Thanks!
zanash
I've some up on ebay with a pic.
Item number: 5785786014
As silver is approx 25% more conductive than copper this wire would be the equivalent thickness of .8mm dia copper.
I use this for audio Interconnects and speaker cable. You can of course put several cores to gether to increase current carrying capacity.
I can also get hold of 1mm 1.5mm 4n wire and also 3mm x0.3mm, 5mm x 0.3mm flat wire but this would be specially ordered [which is not a problem] cost of the 1mm wire 25m will be 4x the price of the 0.5mm plus postage.
If your intrested email me on peter.kendall4@ntlworld.com
awm
No offence here, but for the record, silver is not 25% more conductive than copper. It's between 5-6% percent more. The really significant difference is between each metal's oxides. Silver's barely decreases in conductivity, while copper oxide does substantially. But, these numbers and their percent difference I forget and am currently too lazy to find... :D
You can check material's properties sites and about a million audio related discussions to verify this...
Andy
zanash
Your numerically correct ...what I meant to say was that for the same current carrying cappacity you need about 20% more copper [this depends on a number of other factors including temp and insulation type]. The difference is indeed about 6% [631/mohm/cm for silver to 594/mohm/cm copper].
You are also correct that silver salts are not a barrier to the transmission of electricity as copper salt are. I say salts as it normally sulphides and not oxides in the polluted northern hemisphere that cause the problems.
combine this with an 8% better resistivity over copper.
I was trying to keep it simple.............but did not express myself very clearly.
Page generated in 0.025577068328857 seconds with 17 queries,
spending 0.00823760 doing MySQL queries and 0.01733947 doing PHP things.
