| suitability of this potted transformer for chipamp? - Click HERE for Original Thread |
| jimbo1968 |
First question. I assume can you use a trafo with 4x 11V out to give you 2x 22V out?
Second. Is this trafo suitable (or even good) for use in a chipamp?
http://www.ibl.co.uk/products/datasheets/5302.pdf
hmmmmmmm.... Just noticed that the datasheet says you can't use the outputs in series or parallel.
So, back to question1, in general can you wire trafo outputs in series? and why can't you with this one? |
| moamps |
| quote: | Originally posted by jimbo1968
First question. I assume can you use a trafo with 4x 11V out to give you 2x 22V out? | Yes.
| quote: | | So in general can you wire trafo outputs in series? | Yes.
| quote: | | and why can't you with this one? |
The transformer in question obviously has only one secondary 11.8V, distributed to four individually fused outputs.
Milan |
