diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
help with a bandpass enclosure - Click HERE for Original Thread
idahoxj
Hey guys, I am building a sealed rear chamber bandpass enclosure for my jeep and when I try to figure out the port size I get a rediculously long port size. I think its becuase I am using just the front chamber volume. Should I use the total volume of the entire box?
These are all the specs.
The box
vf=3.664ft^3
vr=9.626ft^3
Qpb=0.88
Fb=28.51
gain=2.39
F(l)=17
s factor= 0.6
I am planning on the box being roughly 45"x17"x32"
The speakers
Qts=.72
Vas=4.908
Fs=23.2
Qes=.84
SPL=85
Thanks in Advance.
Lligior
what was the diameter of the port you wanted? If you go to a smaller diameter the port will get shorter. But as the port gets narrower the air speed picks up, supposedly when this gets to high you can hear the air move. I have built speakers with a resulting air speed that should be audible, but by that time the music is so loud I can't hear it. I realize this dosen't answer your box volume question but it may come in handy if your numbers are good.
idahoxj
I was getting a port diameter of 9.55 inches when I crunched the numbers.
lynchingacers
mabye u could use a slot or a sqaure port so that u can have a port almost as tall as the box. u might consider a smaller port diameteer like 3-4 mabye or even multi ports
MrUnsocial
You're trying to tune it way to low. Tune it around 50hz or higher ... unless you want your in-car response to "peak" at about 20Hz and not play much of anything above 30.
if the vas is in ft^3 then I should one sub looking nice in ~1.5ft^3 rear and 2.9ft^3 front tuned to 48Hz via 6"x6"x8.375" D port ... might play a little low for most people tho ... passband of ~40Hz ... 30Hz to 70Hz
in-car should be pretty mean from mid 30's to mid 50's with a gradual slope above 50 ...
Page generated in 0.020776033401489 seconds with 16 queries,
spending 0.00852799 doing MySQL queries and 0.01224804 doing PHP things.
