diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph L PSU and 50V secondaries - Click HERE for Original Thread
Stabist
I just wonder - original AL has trannie with 60V secondaries - that gives around 85V after CRC filtering and before stack of 9V1 zeners - but I have a 50V trannie at hand - so I'll have "only" around 65-70V after CRC ...
But that should be still enough for desired 60V or is there some other catch and I'll have to recalculate some more values???
wuffwaff
50V will be a bit low. You loose voltage in the bridges and because of the Vgs of the fet. Then you still need some margin to regulate the voltage.
What you could do is to go for 55V regulated, the amp will work fine this way.
William
steenoe
Thats a bit too close to the regulated voltage, as your main supply (The 220v) will drift at least +/- 10%. Just swap out one 9,1v zener with a, say 4v or there about, and you should be fine.
A starving Zenerstring is not supposed to sound pretty:)
Steen:)
BTW. To be sure you dont starve the Zener value, you could just jumper one of them. That would net you some 50V supplies.
Stabist
55V idea sounds great :D
Thanks to both for tips!
Probably I'll do as steenoe sugested - I'll replace one 9V1 zener with 4V one and so get 55V - and then see what will I get out and if there are any major corrections needed in preamp circuitry ...
THANKS again!
steenoe
If your mains supply is steady enough, that should do the trick:) If not, jumper the 4V Zener:)
Steen:cool:
Stabist
Well, I'll see what will be put together in this chassis afterall - original idea was the MiniA + BoZ - so that's why 50V secondaries ....
But in last days I'm thinking of making p2p AL instead ...
Btw - which solution should be better - more simple is to put trannie at the back, than PSU caps and preamp on the front panel - so pot is mounted directly to front plate, etc .... But then again - if trannie at the back - it's probably too close to RCA connectors, etc??? BUT OK, the trannie itself has a shield!
Any ideas or even better - experiences with possible troubles when trannie is mounted at the back ???
Stabist
So this is "another version"
Stabist
The copper is added to improve a bit heatsink's thickness ... They have only 5mm thick "meat" ...
Stabist
The finnal look will be - heatsinks silver (I've got them as 2nd hand and were allready eloxated in sliver ...) and the rest black ...
Not so OK considering heat dissipation - but for MiniA I think more than enough ...
Btw - I plan to have +/-15 to 16V (trannie is 12V) and around 1,4A bias - I need highest power at 5R - and those are the numbers that suits me fine ...
Stabist
I just wonder - the PSU for AL - "the bottom half" in the schematic - that is one irf 610 and irf 9610, relay and some resistors is there only because of that relay? I don't intend to use delay - so I can easilly left the whole thing out.
Btw - would AL make any thumps during powering ON or why was that relay implemented??
Stabist
Stupid me :(
All I should do first was to read service manual and than ask ;) :(
GRollins
Hint: Use a bipolar transistor as the pass device in the regulator.
That way you'll only lose .65V instead of 4V. Adjust the Zener stack to use ten 6V Zeners instead of the 9V ones in the original product. This will make up the difference between the MOSFET Vgs and the bipolar Vbe and you'll end up with the target 60V rail.
Nuthin' to it!
Grey
Stabist
Grey,
thanks :D
Btw - because all I have at hand are 1.3W 20V and 9.1V Zeners - I guess 3 20V will also do the job or are there some other reasons to use more zeners with lower value?
Stabist
Me again ...
Looking for some nice small heatsinks I've dissassembled some old PSUs - and found inside interesting diodes - MBR3045 by Motorola - I gues since they are 30A/45V - and fast shottky ones - they could be a good choice for my MiniA rectification!
It's the version with 2 diodes inside one chassis - e.g.:
http://uk.farnell.com/jsp/endecaSea...U=9100806&N=401
Stabist
quote:
Originally posted by Stabist
Me again ...
Forget it ... After carefull look - I've discovered I have only one type available - and with only it it's not possible to make gretz ... :(
steenoe
quote:
Forget it ...
What do you have? Maybe it will do after all? Don't worry, this community will hold your hand:) :)
Steen.
Stabist
The problem is mbr3045 dual diode is made as the "bottom" half of gretz - anode is common and is a center pin ...
So I should get the other pair - with common cathode ...
Magura
Naah, don't need a common cathode version, just consider each MBR3045 a single diode and use four fo a bridge.
Magura :)
Stabist
Magura - in this case I can use MUR1560 that were primary meant for this job - the thing I liked about those MBR was that I hoped I can use 4 for double bridge ...
But than again - I should check - are MBR3045 maybe a better choice than MUR - in that case - your sugesstion might be worth of consideration ... :D
GRollins
(1 x bipolar pass device) + (3 x 20V Zeners) = Perfect
The reason that most people use small values and stack them is that it's simpler and more versatile to buy small values in bulk (read: cheaper) than to try to stock smaller quantities of each of a half-dozen 'exact' Zeners that would be used in only one design. They make 60V Zeners, for instance, but it's easier for Nelson to buy a great, whonkin' box full of 9V ones and use one for the Vref in the Aleph amp front end, six in the L preamp regulator...etc. Imagine ending the production run of the L preamp and having a couple hundred 60V Zeners left over. What are you going to do with the beggars? Give 'em to the local orphanage? Easier to select one value that can be used in series to handle anything and everything you're likely to want to do. Take CJ as an example. They used to use rows of 33V Zeners in everything (may still, for all I know). There's not a rule to this, it's just what works for any particular manufacturer.
A bit of trivia. Zeners are not as quiet as we might like. For various subtle quantum mechanical, mumbo-jumbo reasons Zeners in the 5 to 6 volt range are slightly quieter than voltages above or below that. If you're doing something where you're striving for the utmost in quietude, try to arrange things so that you can use Zeners in that range. For this application your 20V Zeners will be great--you're not building a NASA deep space probe. It's just a preamp and you're doing this to have fun. If you want to guild the lily later and use quieter Zeners, have at it, but the majority of the noise you hear through the preamp will likely be from the gain device, not the power supply regulation.
Quieter gain devices?
That's another thread.
Grey
Stabist
Finnaly some time left - so PSU is now alive :D It uses BD911 and stack of 6 9V1 zeners - so I have 56,6V at the output - I guess that's quite OK (~3,5V lower than original design) and probably I will not try to change them for 3x20V Zeners ... The thing is - that part of PSU was allready build before reading Grey's advice ... :(
Interesting about the fact of slightly quieter zeners in 5-6V range!!
So now I'll have to make both channels of the ALpeh L on small protoboards and than start slowly connecting all different parts of my Mini Integrated Aleph ... And of course - there ares ome openings to be done on the chassis ... And eloxation ...
Right now it looks like this:
Page generated in 0.3021879196167 seconds with 17 queries,
spending 0.25632668 doing MySQL queries and 0.04586124 doing PHP things.
