diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Chipamp.com pcb with linkwitz 3875 design - Click HERE for Original Thread
akunec
I'm building a gainclone for tweeters and mids using the design shown here: http://www.linkwitzlab.com/images/graphics/3886amp.gif . For Ci, I'm gonna use a 4.7uf cap, but im having difficulty installing it on this chip: http://www.chipamp.com/lm3875.shtml. The problem is that signal ground is connected to both the 20kohm input to ground and the 1k resistor right above Ci. If I put the cap on the signal ground, the cap would be in series with the 1k resistor AND the 20kohm input to ground resistor, which the design does not call for.
How do i solve this problem?
Alex
motherone
Why don't you insert one pin of the cap into the ground side of Ri pad, and insert the resistor into the other side. Then solder the two pins that aren't attached to the PCB together?
akunec
The 4.7uF cap is really large. I don't think there would be enough room to do that.
motherone
Well, you could try using a 50v/4.7uF blackgate-N. They're pretty small. They're available inexpensively over at http://www.kyoto-electro.com or any number of other parts suppliers (parts connexion, etc.)
On the plus side, they're usually a heck of a lot cheaper than an "audiophile" metallized Poly or film & foil cap.
Page generated in 0.020442962646484 seconds with 17 queries,
spending 0.00879431 doing MySQL queries and 0.01164865 doing PHP things.
