diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
NAD 2200 Soft Clip Fault - Click HERE for Original Thread
sudbury
Have an NAD 2200 amp. Seems OK, except "soft clip" indicator on front panel is always lit when "soft clip" switch on rear panel is "on". Other than always leaving it "off" does anyone have experience or pointers re this? Presently do not have a schem nor service manual which enhances joy.
TIA for any help.
Leolabs
Does your NAD sound different when the indicator is on???
pmharries
did you cure soft clipping problem?I am looking for transformer for 2200 dont supose you know were i can get one.regards phil
Rhesusminus
It's supposed to be that way.
The switch has three sections, one for each channel (to enable the soft-clipping network) and one to turn on the led permanently.
Rh÷
Page generated in 0.022775888442993 seconds with 16 queries,
spending 0.01035309 doing MySQL queries and 0.01242280 doing PHP things.
