diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
need a pic software assembled - Click HERE for Original Thread
diyfmradio
Hi there
Im trying to build a project of a cdrom used as a cd player
wich I found on the net
I have a pic programer wich I have used to program several pics
but I dont know how to asemble the asm software
so if anyone would have the time to assemble the software
for me into a hex file i'd be very grateful....
I have attached the project with the software...
waiting patiently.....
Thanks in davance.....
-_nando-_
I need exactly the same thing !
I'm waiting for it too :D
Lucifix
Well... good things comes to those who waits. I made a project with this files in no more than 3 minutes. Hex is included... anyway i don't have a board to test this firmware to see if it works, at least there was no errors. The project can be open and build with MPLAB (mine is version 7.40). Be careful to select Language ToolSuite -> Microchip MPASM.
Best regards!
-_nando-_
I made this !
Easy, create a project with MPLAB, add all files, and then "Build All", and "Make". Then Export Hex File, Bingo !
The file is attached !
Lucifix
The complete project...
annex666
I'm assuming these are Microchip PICs - as such you can download their IDE from the microchip website for free.
This IDE also includes an offline debugger, however I recommend a third-party simulator from Oshonsoft as the debugger included in Microchip's own IDE does not support asynchronous timing events despite what their documentation states (it took me a while debugging a project to find that out, to my frustration!).
Here's Microchip:
www.microchip.com
...and Oshonsoft:
http://www.oshonsoft.com/pic.html
jackinnj
Here's Microchip:
www.microchip.com
...and Oshonsoft:
I think you have to write DEE -- BOOGGGERRRRR -- elsewise the automated web-nannies screw up your epistomology.
annex666
...maybe their obscenity filter is ******ed?
poobah
I think baggur with a "u" and an "e" is a bad word in England... is it not?
:xeye:
annex666
Well yes, bu**er is vulgar slang, however it's not always used as it's direct meaning (the verb form).
Anyhow, debu**er is not rude in any way - it is the process of removing bugs. In this case it was removed due to an oversight more than anything (surprising though seeing as it must have been a programmer that wrote (and debugged!) the filter).
pasan
Hey guys thanks ton. I'm goona make this.
pasan
This one is not working:bawling:
Page generated in 0.029870986938477 seconds with 17 queries,
spending 0.00728059 doing MySQL queries and 0.02259040 doing PHP things.
