diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
4w All Fet Class-a Amp - Click HERE for Original Thread
DarkHorse
hi:
have a look with this circuit diagram,can it works well?
I draw this circuit diagram last night...
RP1 control the currency of output stage,set it to 50K at first;
RP2 control the voltage of ouput point(0.22V+1/2Ucc);
SK170 can replace with sk389 or NPD5564(twins);
Upupa Epops
4 W amp with 1.1 bias current ? What are you waiting from this " miracle " ?
triode_al
quote:
Originally posted by DarkHorse
can it works well?
I'd take the gate resistor R8 of the top IRF510 higher --> 510k too, and add a gate resitor >> 10 ohms.
The input/driver will have reduced distortion as you take a higher Vb there, say 50V. This might be a considerable reduction. It is also something that the feedback in the way you design it, cannot correct. This means that RP1 has to increase along the way.
It does have a Pass flavour to it that is nice. Its simple. What do we want more? Well, Q4 is not really needed, and by having a resister it should work out well too methinks.
padamiecki
hi:
it is fet/mosfet version of Aikido Amplifier by John Broskie, TCJ
DarkHorse
quote:
hi,Upupa Epops :
4W(RMS) is 8W(peak)in sine-wave ,so load is 8ohm,and P=I^2*R,then I=1.0A,so I=1.1A is suitable!
driver stage using SE instead of using bootstrip or using hight-Voltage supply,and it can win more low distortion...
cheers
WINCO
DarkHorse
quote:
I don't know where this diagram from!but it's topology so simply that make me so surprise...
this is original schematic which I referenced:
Upupa Epops
If you take this connection as excercise, so go on. But with four transistors don't wait miracles, although they are relatively modern ones, all is too simply ;) .
DarkHorse
haha:
yes,I understand your meaning.
but as a small "kid"(only 4W output power),it's capability was enough strong,THD=0.15%,phase angle is +0.2 degree(20Hz) and -0.7 degree(20KHz).I think it is so great...
all for it's simply.I like it,and hope it's sound can sweet than ZEN2(the class-a amp I have alread build)..
Fuling
Note that the original circuit is a transconductance amp (current feedback).
DarkHorse
quote:
hi:
yes,I have note this problem.
current FB is can cut-off the speaker's reverse voltage...
but distortion is too XXX(4%).
see you tomorrow.
Upupa Epops
Better sound than Zen ? Your references are too low :D .
padamiecki
you are right
my look was too quick
I have mismatched it with mentioned TCJ
DarkHorse
I will build a sample to examine the sound class of this circuit,wait for my report please!about the day after tomorrow...I show you.
enjoy!
:smash:
tlf9999
There are substantial differences between yours and the original design but I like yours better.
Yours has the gain in the first and 2nd stages: both are drain-loaded-with-CCS and with global feedback. The original is a source-follower, followed by a drain-loaded with CCS for gain, without any feedback.
It is my experience that it is easier to have gain with small signal. So I was wondering if you can improve upon your design by using a source-follower in the 2nd stage (source follower + CCS).
You can then limit the feedback to the first stage as well (you can look into the Zen to see how to implement feedback in the first stage).
Let me know what you think.
DJNUBZ
I bet this would sound great with some high effeciency speakers. There is a lot you can do with 4 wrms a chan.
UltimateX86
http://www.selectronic.fr/upload/pr...ique/7480SM.pdf
schematic like this :
but with gain and current feedback
a Zenquito without driver ...
DarkHorse
hi,tlf9999:
At first I really don't know would it sounds better than the original version, because global feesback can cause other unexpectable problem...maybe it just decrease distortion in parameter..low distortion not mean it can sounds well..and I am so afraid the speaker's reverse voltage loop back and effect the first gain stage..
I don't want to use source-follower,I think IRF510's C-input is 180pF,driver current in 10mA is suitable.too strong driver stage perhaps let sound comes too "hard"(not sweet),I think..
but if you want use IRF530 or IRF540..this source-follower is needed to high frequency(10KHz or more)..
quote:
hi,DJNUBZ:
in fact,this circuit can output 4.5W(RMS) with 1.1A bias current.
have fun!
WINCO
:D
DarkHorse
Hello,UltimateX86:
thanks your schematics,the topology is OK:
Ipanema
Hi Ultimate86,
Your circuit looks like a Le' Monstre variation. Have you build those?
Ipanema
DarkHorse
look my works,I soldering this last night...but too late,didn't finish yet!
DarkHorse
main section closer view,I didn't find R11(47ohm),so I replace it to 68ohm,and R14 is 1.5Kohm,gain about 23:
:smash:
DarkHorse
the PCB,I cut the line wire using a knife,is a hard work!!!
:bawling:
DarkHorse
and using SEC's IRF510(second hand).
I will test it tonight,god bless me!
:cool:
UltimateX86
quote:
Originally posted by Ipanema
Hi Ultimate86,
Ipanema
I built a Zenquito, which is a kind of evolution with MOSFET of "Le Monstre"
http://www.bonavolta.ch/hobby/en/audio/monster.htm
l http://perso.wanadoo.fr/jm.plantefeve/home.htm
ProFet that I proposed has neither cascode nor driver !
Just Jfet input + Mosfet output ... but I do not have the complete diagram
DarkHorse
hi,all:
I test it last night.
it works abnormality ,that is to say---it doesn't works well,
result show it has about 0.5Hz surge,because first stage's low frequency gain is too strong,R3 should not connect to feedback loop,it's positive feedback...
so I decide to use other bias way(SK170's)...
look it's ac analysis graph:
DarkHorse
Take it easy!I will go on tonight,it has more suitable topology,and lower distortion...I believe it can sounds perfect!
the test in last night,I relocate R3(down end) connect to ground.
the surge problem removed,but the output point of first stage upto about 14V,no matter what,it sounds,and sounds pretty good,I can't hear any noise from the speaker,I only use one 10000uF/50V cap and shunted with one 10uF/100V MKP cap,
ouput stage's bias current is about 1A..
step by step,I walk to success...haha
this is updated version of schematic:
:D
padamiecki
cheers!
could you unconnect nfb and describe the sound after deconnecting?
DarkHorse
cheers!
hello, padamiecki :
nfb???
it's hard to say that now,but I will tell you tomorrow!
regards
WINCO
:smash:
UltimateX86
http://www.selectronic.fr/upload/pr...hnique/4180.pdf
DarkHorse
:bawling:
fail again!!!
the super low surge(0.5Hz) still existing!
I suppose it's open loop gain rate is too high,and the feedback is too deep,so it occur...isn't it???
last night,after the failed testing..I had to remove the Q4 and RP3,
replace with one resistor,the value is 1Kohm...it sounds:
the sound is so soften and sweet,put my ear close to the loud speaker,about 0.3 meter(1'),I only hear the heat noise of semiconductor device..no 50Hz low frequency noise---good!
sound quality is more than my ZEN2,I hear Michael Jackson's "billie jeans"...you can lisend it for a long time,didn't feel any uncomfortable and any noisily...
I will go on!:mad:
padamiecki
quote:
I have used he same circuit,
but without nfbes,
even local
my posts should be somewhere here in solid state forum
but for some person the sound was too weak.
With nfb connected the sound becamed nervous.
DarkHorse
but without nfbes,
even local
hi:
your "nfb" is means "globe feedback"?
I think "nfb"is "none globe feedback".
but not all "globe feedback" connect would make sound became nervous,only occur on which circuit using high power transistor(with big input capacitor,as if IRF044,IRF140..),and amp has high gain rate,and deep feedback loop,this C-input will effect the sounds,phase compensator almost using a cap(10pf---47pf) shunts with feedback resistor,lead to "TIM" distortion...
I think if the output transistor(IRF510) has small C-input,it's effect will reduce more,and it can sounds sweet too...
cheers!
WINCO
padamiecki
cheers!
WINCO
maybe, who knows? :spin:
UltimateX86
but without nfbes,
even local
what is certain, it is that French likes it
padamiecki
so maybe is there in the world a definition "The French sound?"
tlf9999
Here is my variation.
It is essentially the same front end as DarkHorse's design. Except that in the 2nd stage, rather than using a drain-loaded output stage with gain, mine is a source follower.
Simulated quite well, and harmonics are mostly 2nd, 3rd and 4th, with the 2nd harmonics dominating.
Warning: conceptual design, never meant to be built, not optimized.
tlf9999
One quick comment: the feedback pick-up point (right side of R3) can be at either the MOSFET's source or on the load.
bocka
Hi DarkHouse
You MUST NOT load a collector or drain follower with a current source when there is no way that global feedback sets your DC operating point. This is a no no and only works in simulation. .:whazzat: Both FETs are not equal. Use a resistor instead. Maybe this is also the problem for your 0.5 Hz surge
DarkHorse
quote:
Originally posted by bocka
Hi DarkHouse
hi,bocka:
yes, you are right!I remove R14 away,the circuit can works well,and I have try 10Kohm /7.5Kohm /5.1Kohm of R14,I find R14 must large than 5.1Kohm that the circuit can works!
let's see the last passed test circuit:
DarkHorse
as a class-A amp with 1.1A current bias,let it's input end shunts to the ground,put your ear to the speaker,nothing you can hear!
the filter cap just only 10000uF/50V and 10uF MKP cap...
it sounds so softly and sweet...I like it!
lineup
put your ear to the speaker, nothing you can hear!
can such a simple class a mosfet amplifier really perform
would be interesting to know, really ;)
Is my attachment a correct schematic ??
of The Final Version of this All FET Class A amplifier
Page generated in 0.093767881393433 seconds with 17 queries,
spending 0.01467657 doing MySQL queries and 0.07909131 doing PHP things.
