diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
gainclone and equalizer - Click HERE for Original Thread
JOJO847
Helloo
What do you think about tone controls for lm3886 ?
I'm planing to build this project
http://www.web-ee.com/Electronic-Pr...hic/index.shtml
so, i want to hear your opinion about this project
PS: I'm sorry if someone already asked this question
slackman
Hi Jojo,
if you want to build a GC to improove the sound quality of your existing system (that's mostly the reason why people build ther own amp) than an equalizer makes no sense, esp. that one from your linked project.:whazzat:
If you plan to build an integrated amp with all klicki klacki, feel free to implement everythink you want... But than you don't need the LM - chips - take cheaper ones (TDA,...).
Michael
JOJO847
look my situation and help me :)
Let's say that my speakers are good ( dali 4ohm 100w 3 system )
And yes, i want to improove a sound quality.
So, lm3886 is an good choice but without tone controls?
macboy
I would recommend basic bass/treble tone controls rather than a five band EQ. A nice example of such is Rod Elliott's Hi-Fi Preamplifier. And his Expandable Graphic Equaliser circuit almost certainly outperms the one that you referenced.
No matter which you choose to build, do not use LF347 opamps! I almost choked when I saw those in that EQ circuit. The PCB for that circuit is designed for quad opamps, so a suitable replacement would be National's LM837. You could also try the TI/Burr-Brown OPA4134 but they cost a lot more.
JOJO847
and what about TL074?
macboy
TL074 will work fine, and will be a big improvement over LF347. It is a little noisier than the others I mentioned (but by no means too noisy).
Page generated in 0.18335103988647 seconds with 17 queries,
spending 0.07565451 doing MySQL queries and 0.10769653 doing PHP things.
