diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
How to match the FET - Click HERE for Original Thread
TjongKristian
Dear All,
I am a beginner in electronic world and want to learn to build an Amp. After doing some searching and reading, I stumbled how to macth the fet. I read Mr. Nelson Pass article on matching, and I think :rolleyes: I understand the concept behind it. Unfortunately, I do not understand the schematic. For example, it is my understanding that in matching, let say, N Fet, I have to connect positive supply to a resistor and then connect it to Drain and Gate with the Source grounded and then take a measurement across the Ground and Drain. Is it Correct? Last question, I came across a product which I think will do the same job, here is the link, http://www.peakelec.co.uk/products/atlas/atlas.htm
Has anyone used this product? Thank you for your help.:angel:
Nelson Pass
You have it correct.
:cool:
jackinnj
This is a link to International Rectifier's ap-note on testing FET's. They use a Tektronix 576 curve tracer, but you can perform many of the same tests with a good DVM -- and they explain how. Note, before trying these out that many of the tests are performed with a pulse generator -- I think that they use 80uSec pulses to measure gm. I use 100uSec with a Tek PG501 pulse generator.<p>http://www.irf.com/technical-info/an957/an-957.htm
Page generated in 0.025041103363037 seconds with 17 queries,
spending 0.00781488 doing MySQL queries and 0.01722622 doing PHP things.
Please support our sponsor.
