diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Isolation transformers - buzzing - Click HERE for Original Thread
schpeltor
I just picked up a couple of 1KW isolation transformers. They're mounted in a thick steel box. I haven't looked inside yet to see whether they have any other kind of line conditioning, but I'm assuming not. When I plug them in, whether or not there is any load, they vibrate and buzz very loudly (for a transformer at least). Is there any way of getting rid of this ? maybe by adding an AC filter before it or something?
thanx
JasonL
mabey see if the screws / bolts that hold the transofmer to its case are tight or see if it is rattleing against the case i have had that happen on things like thoes and that was what the problem was..
it is awful buzzing sound too..
trwh
Hi schpeltor,
One of the main causes of transformers radiating mechanical noise is a small DC offset on the mains. This can be removed by AC coupling the mains input - there was a thread discussing this and someone posted a schematic for a suitable filter.
I've used AC coupling to quieten down a cheap EI transformer in a CD player before, but I'm not sure if it would still be practical for a 1kVA unit.
Anyway, 's food for thought,
Tim.
schpeltor
In addition to filtering the mains input, what about potting it in some substance? I found recommendations for epoxy and shellac while searching the forum, what would be the best compound to completely encase the transformer with?
MRehorst
Are they isolation transformers or are they line voltage regulators/conditioners?
Ferroresonant line "conditioners" all buzz and run warm even with no load. If you look inside and see large capacitor(s), they are ferroresonant. There is no way to make them quieter except to unplug them.
MR
schpeltor
I believe its just an isolation transformer. I looked and the only things inside are a transformer and a circuit breaker.
NU_NRG
quote:
Search Compagnies that make epoxy, I've seen one (sorry son't remember the name) that made speacial epoxy for potting.
MRehorst
If you pot the thing, you have to worry about heat build-up, and there's no guarantee you'll get the goop into the small spaces where it needs to get in order to be effective.
I restore "antique" radios and one of the old timer's tricks for fixing a buzzing transformer is to whack it on one of the corners with a wood or rubber mallet. In the case of a large transformer, you might need a wood or rubber sledge hammer...
MR
ShiFtY
It really is worth just tightening the bolts up on the trannie, this fixed a noisy one for me. The other one I had to take apart and the bobbin was loose on the core, jammed a corrugated metal wedge in there, now its silent.
Page generated in 0.027973890304565 seconds with 17 queries,
spending 0.00725722 doing MySQL queries and 0.02071667 doing PHP things.
