diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Parallelling power supply chokes??? - Click HERE for Original Thread
Klimon
I was wondering: could you connect two chokes in parallel, to double their max. mA rating, or would this have a negative effect on sound quality? I have some 60mA chokes lying around that I'ld like to use for a small power amp, but 120mA would seem a lot more fit for that job! I've never seen parallelled chokes on a schematic however :rolleyes:
Thanks!
kianbach
Hi,I've paralleled a pair of 10H 120mA chokes in the first CLC stage of my latest power amp which draws 240mA with no probs,This is followed by an LC stage consisting of a 10H 300mA choke and 100uF filter cap.Sounds really nice.The second LC stage made all the difference.:D
blmn
If both chokes have the same inductance, it will result in a half inductance value for the paralel mount.
Klimon
Okay, I'll give it a go then. A second L stage with higher H seems indeed the way to go when H of the first parallel stage are only half. Thanks guys - and nice looking amp, Kianbach!!!:D
kianbach
Thanks for the compliment but this is only the prototype test version.I'm waiting for my custom wound mains and output trannies for the final version.
Page generated in 0.028276920318604 seconds with 16 queries,
spending 0.00780654 doing MySQL queries and 0.02047038 doing PHP things.
Please support our sponsor.
