diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
designing inputs + outputs of electronic crossover - Click HERE for Original Thread
stinkpot
So I've decided to build an electronic crossover. Do I give it line-in or speaker-level inputs? In other words, do I position between my source and my amp or between my amp and my speakers?
Thanks!
-LD
richie00boy
In between source and amps.
audiousername
quote:
Just to make sure nothing gets lost along the way, that means line-level ;)
AndrewT
yes line level.
Most amps require a MAXIMUM signal of 200mV to 2000mV. Your spec sheet should tell you what your sensitivities are. You need the same gain in each filter/amp/speaker combo. If all your speaker units have the same sensitivity and all you amps the same gain then you can manage without gain adjust on the filter outputs. Otherwise add a buffered gain adjust.
The voltage that your filter opamps run at could be +-15Vdc. The maximum signal through the filter string and output will be approx (15+15)/3 Vrms i.e. about 10Vrms into a high impedance and somewhat lower into lower loads. This will easily drive any unbalanced amp input with an impedance >=10k.
dmfraser
By definition an electronic crossover is a line level device. Your power amps always come after the electronic crossover.
Bill Fitzpatrick
Stinkpot:
I notice you said amp, not amps. If you have one amp only, you have no use for an electronic crossover. You need 2+ amps; one for each frequency band.
stinkpot
Thanks all for the info.
Bill:
I have a powered sub, so that's the second amp.
Everyone:
I guess I phrased the question this way, because I have been thinking of getting an integrated amp that may or may not have pre-out/main-in jacks. As a result, I was trying to figure out where to stick the crossover.
Bill Fitzpatrick
If the integrated has no pre out/amp in then you don't have use for an electronic crossover either.
planet10
quote:
But it doesn't say where you get the input signal for the XO. In a case where you have no pre/power inputs on a receiver or integrated, speaker level inputs can be used (almost every plate amp has them). This is usually considered a compromise, but there is a school of thot that has the SS sub amplifier feed from the output transformers (ie speaker level) of a SET to get better integration of the sonics of the woofer & the speakers on the top.
dave
dmfraser
Yes but you still need power amps after the electronic crossover. Besides, when the signal is taken from speaker level it has to be greatly attenuated. Even a sub plate amp has a power amp built in. Perhaps the originator of the thread could more fully describe what he was trying to do.
dmfraser
If indeed you are merely trying to make an electronic crossover for a sub woofer, you can indeed use the speaker level outputs of your source. You just have to attenuate the signal to line level. Use resistive dividers to attenuate the signal about 10:1. Then run this through the sub-woofer filter, while running the other speakers full range, and after the sub-woofer filter, to a sub power amp.
There may be some subwoofer crossover designs at www.schematicsforfree.mattsoft.net
stinkpot
thanks a lot for the info guys - i apologize, i think i may have mispoken:
by electronic crossover, i meant an active cross-over (i thought they were synonymous but perhaps not).
in any case, i'm not sure i want to build another filter to attenuate the speaker-level signal and then feed that into the XO - what a mess.
i guess i'll just keep an eye out for an integrated w/ pre-outs.
richie00boy
Not really a mess. Just 2 resistors per channel different to if you had line level feed.
Page generated in 0.032512903213501 seconds with 17 queries,
spending 0.00791216 doing MySQL queries and 0.02460074 doing PHP things.
