diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Substitute Lateral Mosfets - Click HERE for Original Thread
joensd
hello,
this might be some stupid question so thanks for listening ;-)
iīm about to start some mosfet amplifier project and already look for parts and designs.
the 2sk1058/2sj162 combination is often seen and known to be good and reliable.
these are lateral mosfets but how do i know with which devices i can substitute them.
i was thinking about 2sk1530/2sj201 cause of the lower price.
in anthony holtons design "lateral mosfet amplifier" he notes you can exchange 2sk2221/2sj352 with sk1058/2sj162 but in no case with for example irf240/irf9240 (which would even blow them up).
so what do i have to look for?
TIA
Jens
Christer
There are two UK companies manufacturing equivalents for
the Hitachi devices, Semelab and Exicon. The Semelab ones
seem to be about the same price as the Hitachi devices, but
it seems Exicon are quite a bit cheaper. Have a look at the
following link. Unless I misunderstood something, there is
no minimum order and no extra cost for shipping etc.
http://www.profusionplc.com/hitachi.htm
Otherwise, Sloane uses the SJ162/SK1058 in all his MOSFET
amplifiers, and he mentions that IRF640/IRF9640 can be used
as a replacement in som of his designs, without furhter details
on which ones, or under what conditions. If memory doesn't
fail me, someone made a claim in another thread recently that
only lateral MOSFETs have a negative temperature coefficient, so
replacement with non-lateral devices without adding some
temp. correction/protection circuitry may not be so wise.
UrSv
Jens,
If you want you can drop me a mail if you need some 1530/201 pairs.
/UrSv
P.Lacombe
"only lateral MOSFETs have a negative temperature coefficient, so
temp. correction/protection circuitry may not be so wise."
Yes. Non-lateral MosFets are more fragile, and exhibit positive temp co at usual current in audio amps. Another problem is higher transconductance, which can cause HF oscillations under some circumstances.
Regards, Pierre Lacombe.
joensd
thanks for hints
but iīve overseen a long thread about 2sk1058/2sj162 which talks about substitutes
and iīve decided to built the crescendo ME version anyway.
itīs an amp with sk1530/2sj201 and those are easy to get here (thanks anyway UrSv)
UrSv
Sure Jens,
I have 52 pairs I am not using so it was jus a thought. (Maybe this belongs in the Tarding Post forum...)
/UrSv
joensd
wow. you must have a good shopping budget!
or are you building amps daily?
just if i get inspired to build more mosfet amps:
where do you come from ?
itīs not in your profile
jens
UrSv
It's in my profile now...I am on both sides of Germany. ;O)
Building far too few amps but starting to pick up speed. The pairs were for a set of A75 but I never got the hang of if they would be OK or not and now I am building a P1.7 and some A30/60s (decision not made - part gathering going on).
/UrSv
Christer
I think the sk1530/2sj201 are discontinued. At least Hitachi
seem not to produce them anymore. There is nothing wrong
in using them, of course, if still available, but it may be wise
to buy a few extra, just in case.
Since they are discontinued, Hitachi didn't provice any
datasheets. how do they compare to SJ162/SK1058, and
why would they be preferred?
UrSv
As far as I know they are not Hitachis but Toshibas and I think they are still in production. At least Elfa in Sweden, Schuro in Germany still list them...
Go to http://www.elfa.se/ and enter 2SJ201 in the upper left search window. You will get a list of 2SJ201 and 2SK1530 when selecting the hit. The little blue button with the i on it will give you the respective datasheet.
/UrSv
Christer
You are quite right UrSv. I admit being a bit embarrased to
miss that, since Elfa is my local supplier. :) You are also
right that these are Toshiba devices according to the datasheets.
However, searching for these part numbers at Toshiba does
not give any hits, whatever that means. BTW are you sure these
are also lateral devices, since the datasheets do not say
anything about that?
UrSv
Christer,
Try:
http://www.toshiba.com/taec/cgi-bin...CategoryID=7007
Most of the stuf is on:
I have no idea if these are lateral devices (list says pi-MOSII). I just responded to the post on this pair earlier in the thread. And Toshiba seems to list them as mass production:
http://www.toshiba.com/taec/compone...anumlisting.pdf
/UrSv
Christer
UrSv,
Yes, those links worked better. I searched the main japanese
site, and didn't find them there. Incidentally, the datasheet links
do not work on the american site, but I got them from Elfa
anyway.
I think SJ301/SK1530 are not lateral MOSFETs. I assumed them
to be from the original post in this thread, but maybe I
misunderstood Jens. This is also why I assumed them to be
Hitachi devices, since I think only Hitachi makes lateral MOSFET
(apart from the british second sources).
The temperature behaviour of SJ201/SK1530 does not look
very promising as a replacement for lateral MOSFETs, but I
am no expert on MOSFETs, so I leave that to others to judge.
I still do not understand Jens' claim that they are cheaper
than SJ162/SK1058, at least it is the other way around here
in Sweden. Or maybe he assumed paralleling the latter devices
to handle the same power?
joensd
christer,
at first i just couldnīt get the 2sk1058/2sj162 from a cheap and near distributor so the 2sk1530/2sj201 were effectively cheaper for me. but then i saw them at www.reichelt.de for same price as the 2sk1530... at www.nedis.com.
that the latter devices have positive temperature coefficient
was almost reason for me not to build the crescendoME
but the PCB includes protection for everything, dc-servo, bias
so i donīt have to worry.
about dicontinueing the devices...
i donīt think so but i might be wrong.
you guys make me real nervous about getting more.
:bawling:
moneyīs gone (loads of watts cost loads of bucks)
greetings
jens
Christer
Jens,
Don't worry. I misunderstood your original post and believed
that SJ201/SK1530 were also lateral MOSFETs and so belonged
to the set of discontinued devices, since Hitachi seems only
to produce the SJ162/SK1058 and maybe some different-voltage
version of them. These are in mass production by Hitachi, and
also second sourced by two UK manufacturers.
The SJ201/SK1530 are probably non-lateral devices, primarily
intended for switching. If the particular design includes all
the necessary temp. compensation and protection and is
designed to use these devices, then it should be OK. Probably
you could use the lateral devices instead and skip the extra
circuitry, but I know nothing about that particular amplifier.
Christer
Jens,
I just checked www.reichelt.de and that seems to be bargain
prices for 2SJ162/2SK1058, about half of what I have to pay
here in Sweden, and much cheaper than the Semelab clones
also. I still think Exicon devices are a bit cheaper, but not very
much.
joensd
i really checked many companies, distributors in germany
but still if you can get the part from reichelt, just buy it there.
in 99% of the cases itīs the cheapest and one of the fastest likewise. just look at the prices for transformers.
maybe we should post all of our favourite distributors, companies so we could make up a big link list for everybody all over the planet to get best prices/services for diyīers !?
or is it getting too commercial then?!
UrSv
Christer,
I actually think 201/1530 were specifically designed for audio amplifiers and are used in the Crescendo (AFAIK) as well as Anthony Holton's symmetric amplifier (http://www.aussieamplifiers.com/).
Datasheets are available on the Jap page:
http://doc.semicon.toshiba.co.jp/pd...123/e001355.pdf
http://doc.semicon.toshiba.co.jp/pd...123/e001264.pdf
/UrSv
Christer
UrSv,
Do you have any particular reason to believe the Toshiba
devices were designed for audio usage? My guess is not,
since the datasheets give the usual data supplied for
switching devices, but not some of the typical data usually
supplied for devices intended for liinear usage. Furthermore,
as far as I know (which may be wrong) the only PowerMOS
devices designed for audio are the Hitachi Lateral MOSFETs,
and all other are primarily intended for switching.
A lot of amplifiers do use ordinary switching devices in the
output stage, and with proper design that probably works just
fine. My understanding is that the lateral MOSFETs primarily
makes the design much simpler and more reliable.
On the other hand, Toshiba does have a family of bipolar devices designed for power audio amplifiers, including both driver and OPS devices.
UrSv
Reason for believing they are for audio? Oh I don't know but I think it might be that:
* I have only heard it described as for audio
* The datasheet describes it as High Power Amplifier
* It does not list Rdson (AFAIK) which would be nice for switching
* It is listed as OUTPUT in the product list
* It has a complimentary (not always the case for switchers)
* It is somewhat popular in amplifiers including high-end
* It is never listed as switching which they usually are: Try:
http://www.chipdocs.com/catalog/tree.html?selid=200
They would share this with the 2SJ200/2SK1529 pair.
I am not an expert on different FET types but this is listed as pi-MOSII and not PowerMOS. I would expect most of those terms to be unique to the manufacturer (Like HEX-FET). Lateral, vertical and others I presume are construction description so that would be something else.
/UrSv
Christer
UrSv,
You are quite right the datasheet says "High power amplifier".
I had already forgotten that and only looked at the actual data
when rechecking the datasheet. Sorry about that. Since no
fT value was specified, but all info about rise and fall times etc.
and also a switching test circuit was supplied, I inferred that
it was a switching device. The RDSon value is missing in the
datasheet, just as you observerd. Incidentally, it is specified in
the general power transistor catalogue
http://www.semicon.toshiba.co.jp/en...pdf/217_242.pdf (p. 237 or p. 21 within this particular document).
which simply lists all MOSFETs as general purpose. I am not
an expert on the subject, but since MOSFETs don't have any
problems with minority carriers, perhaps there is no real
distinction between linear and switching devices, so the usage
and labelling is more arbitrary than for BJTs? I think I have
seen quite a number of amplifiers actually using switching MOSFETs, but maybe I am wrong there?
Regarding "PowerMOS" I simply meant that as a general term
for all power MOSFETs, but perhaps it refers to a specific type
or brand (it does sound a bit familiar).
BTW, please note that I don't mean to argue with you. I am just
curious to find out what these devices really are.
UrSv
Christer,
Sorry of the respons came across as a start of an argument. It was actually nothing more than a shortlist of why I believe it is for Audio and possibly also a glimpse at the lack of "definitive" facts on the matter.
Trivia 1: Our Swedish homeboy M Bladelius uses them in the Advantage product line.
I am definitively not the man to say if a MOS switching transistor is better or worse than a transistor specifically designed for Audio but as you say switching type transistors seem to be used quite often. However I think the types are generally the more general types rather than the most specialised switching types.
/UrSv
Christer
UrSv,
No need to worry. It was I who was worried it might look as if
I was starting to argue. Well, you know how we swedes are. :-)
Besides, being new to this friendly forum, I just don't want to
start out giving the wrong impression.
Dozuki
For What its worth, I have used the Toshiba 1529/200 pair in a design. I do like these FETS. I am planning on using the Hitachi 1058/162s next.
So for clarification, Evolve Amplifiers site in Japan list these (1529, 1530, 200, 201) as designed for Audio.
Also, they ARE lateral, but the neg. temperature coef. doesn't kick in till 6 Amps for the 1529/200 and about 8 Amps for the 1530/201. This defeats the positive aspects of the negative temp. coef. I.E. temp compensation is needed (via Vbe multipier).
One other thing of note is that the voltage bias to turn them on (for class B) is lower than for the IRF type devices. The toshibas needed a bias of about 1.4 - 1.6 Volts each to turn them on, and I found the IRF 540/9540 to need > 2 Volts. I suspect that these devices will run a bit cooler with regards to this, but I havn't actually tested to see.
I also think that Holten's 'Scalable Power Amp' could be modified to use any device keeping in mind the Biasing and temp compensation circuitry needed for the devices that you would use.
-Dozuki
jcarr
Dozuki is correct. Toshiba originally had an audio sub-brand called "Aurex", and at the beginning of the 1980s, Toshiba's semiconductor division introduced a pair of devices called 2SK405 and 2SJ115, and these were targeted for Aurex's audio power amps. The 2SK1529/1530 2SJ200/201 are second-generation audio power devices within the same pi-MOS lineup.
"Pi" refers to the current-flow pattern within the devices. These particular devices had many interesting characterstics about them, but I won't go into detail right now, as they are Out Of Production.
The 2SK1529/1530 2SJ200/201 need some thermal compensation measures, but not as comprehensive as would be required for a high-current switching MOSFET. A simple VBe multiplier, a thermal-coupled diode, or a thermistor should suffice. Of course, the amplifier designer is free to implement more elaborate schemes if he so chooses.
The Hitachi 2SK1056~1058 2SJ160~162 are electrically the spitting image of the older 2SK133~135 2SJ48~50 family, and can by used with a very simple resistor bias network.
regards, jonathan carr
mrfeedback
The Exicon 10N20 and 10P20 To-3 devices are used in quite a few
high power PA amps and are reliable.
They also come in a flatpack version and are cheaper than the Hitachi devices.
Also probably better long term availability too.
Eric.
peranders
quote:
Originally posted by Christer
Since no fT value was specified, but all info about rise and fall times etc.and also a switching test circuit was supplied, I inferred that it was a switching device.
Note that fT is never listed in datasheets of FET's.
The interstings things are switch times, capacitances and the inductances (bond wires).
My idea about the advantage of lateral fet's is the almost constant gm, good for distortion. The disadvantage is the high output impedance.
1 A, 1 Ohms, lateral
1 A, 0.05 ohms, BJT
5 A, 1 Ohms, lateral
5 A, 0.005 ohms, BJT
mirlo
What do you suppose makes them so linear?
Extremely short channel length devices have linear behavior, but I doubt that is how these things achieve it.
The reason Ft is never listed is that it is easily calculated from the input and output currents of a common source amplifier:
Iin = 2*pi*f*Cgs*Vin.
Iout = Gm*Vin.
in which Vin is the (small signal) amplitude of the input sinewave.
Ft is defined as unity current gain, ie Iin = Iout.
So Ft = Gm/(2*pi*Cgs)
For most MOSFETs this is too bias dependent, becasue Gm varies nearly linearly with Id. But these lateral ones are odd in that after about 1A of drain current, they become linear. Maybe it is velocity saturation as in short channel FETs after all.
angel
Would you say they can be used with a simple resistor for bias, like the Hitachi devices suggested by jcarr? If so, at what current?
jacco vermeulen
quote:
As a frequent reader of Mr Carr's posts it's well worth to keep these theads somewhat alive, imho.
For a reason that is yet to become obvious for me, a part of the 2SK405/2SJ115 production was used in UK power amplifier products.
Page generated in 0.08171010017395 seconds with 17 queries,
spending 0.00989318 doing MySQL queries and 0.07181692 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
Please support our sponsor.
