diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
infity gold speakers - Click HERE for Original Thread
taylorjus
i have a 95 jeep GCL with a infity gold system in it, i herd that if you have to change the door speakers, like i do, then you might as well get a new head unit and a new amp, because you would need to rewire the entire system. IS THAT TRUE???
Volenti
I doubt it, most competent installers should be able to make a replacement pair of speakers fit/work even if the car has a wierd setup, you may need to take it to a shop first so you can buy a set of speakers that best fit the location.
pinkmouse
I moved your thread to a more appropriate place. ;)
Staticjeep
No it is not true. I have done that before i got my system. I replaced the facotry speakers with Pioneers. Its not hard either. Might want to get some mounting brackets though.
Page generated in 0.024235963821411 seconds with 16 queries,
spending 0.01421165 doing MySQL queries and 0.01002431 doing PHP things.
Please support our sponsor.
