diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Stripping Phantom Power - Click HERE for Original Thread
Biffa
Does anyone have a simple circuit to strip phantom power from an input. I have a mic level input on a camcorder that has non-switchable phantom power. Presumably some sort of DC blocking Caps arrangement would be required?
Many thanks
Biffa
moamps
What type microphone and input connector is used?
(stereo input thru 3.5 jack or mono-balanced thru XLRF)
loonatron
If it was a normal XLR type mic connector you could disconnect the 6.8k resistors that usually connect to pins 2 and 3 but as for camcorder mic power I have no idea.
Biffa
It's an XLR 3 pin female that delivers 48V in the normal way ( Distributed on pins 2+3 through 2 x 6K8 resistors so pins 1-2 read 48V as do 1-3). I need to plug a line signal, padded down 60 dB to mic level, into this input without getting power back to the line output. I figure Caps inline with each power leg would do the trick but I don't know values required.
Biffa
pinkmouse
10uF is pretty common in this application.
moamps
Page generated in 0.018624067306519 seconds with 16 queries,
spending 0.00679255 doing MySQL queries and 0.01183152 doing PHP things.
Please support our sponsor.
