diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Need replacement part for Tek 466 - Click HERE for Original Thread
MikeB
Hello !
Is there anybody having a replacement tek-part "155-0115-00" ?
This is a hybridchip-amplifier for vertical deflection in a tektronix 466...
Seems not to easy to get this part ! :bawling:
The rest of the scope seems to be in perfect condition, so i would
really like to get it running again !
Any help would be great !
Mike
jackinnj
quote:
Originally posted by MikeB
Hello !
Mike
the only way to get some of these parts is to cannibalize another Tek scope -- this model will run anywhere from $20 to $200.
MikeB
You mean the "make one out of two" method ?
jackinnj
i was lucky to find a 5L4N spectrum analyzer plug-in "parts unit" -- lucky because the other one I had was missing the "miller integrator" chip -- cannibalization is one way to go -- much easier in the US than Europe as we have a huge surplus market with low shipping prices.
the prices of some analog scopes are so ridiculously cheap that you might just get another 466.
it's a pity too -- an analog scope will never lie to you, a digital scope often doesn't tell the truth.
MikeB
The tektronix scope here in ebay-germany get quite high prices,
even the defect ones...
Especially the 466 storage-scope seems very recommended...
The one i got is definitely valuable, it has emi-shielding and isolated
inputs, means i can measure 2 channels with seperate groundings...
Also all the knobs, printings and so on are like new.
Otherwise i would resell it...
Mike
Whit
You might want to try here:
http://www.sphere.bc.ca/test/tek-parts/tekparts3.html
MikeB
Yep, thanks !
But this was the first adress i tried, but this part is on status "sorry,sold"...
I already asked by email, they really don't have one !
Mike
tekman
2 MikeB:
A vertical amp hybrid from the 465 or 465B will work. Easier to get ;-)
Once you have opend your scope: Make shure to check the electrolytics in the LV supply, they often go bad due to age ("dry" caps)
hth,
Andreas
MikeB
Hi !
I thought it's the same chip ?
But, i was able to buy a new chip, was not cheap, 60us$...
Will replace it the next days.
How do i check these caps ? Optically they are fine...
And the scope needs ~2 days to discharge, after turnoff i
measure still 3v in the supply for days, they should be fine ?
Mike
tekman
That is what I said: it is the same chip in these different scope types (465/465B/466. 7633 should have same too)
For caps: No, your method is not gving info about good caps in the way we need it here for this scope. If you want to make shure the caps are ok then you have to check for ESR . Do a google search .
Or look here : http://clientes.netvisao.pt/greenpal/evb1.htm
Buy one ESR meter and you will enjoy this as a VERY useful addition to your testbench.
hth,
Andreas.
Page generated in 0.028971910476685 seconds with 17 queries,
spending 0.00762868 doing MySQL queries and 0.02134323 doing PHP things.
