diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Salvaged Power Supply (100kb+ pictures) - Click HERE for Original Thread
Killjoy99
A couple of weeks ago I caught a large Power supply at my work that was on its way to garbage. I realized by looking though the fan grill on the side that there were some fairly decent looking heatsinks inside. Here are a bunch of pictures before and after disassembly.
I'm obviously going to keep all of the heatsinks components inside as well as the capacitors but is there anything else inside such as the large toroidal devices that I should keep?
-Brian
jackinnj
those heat sinks would make one nice amplifier. APC is one of the largest manufacturers of uninterruptible power supplies.
Killjoy99
I attempted to calculate the dissipation specs on those sinks but couldn't quite get it.
I’ll post the exact measurements when I get home from work, but I would estimate them to measure roughly 3.5 inches wide, 7 inches in length, and 4 inches tall. The base plate is a little over 1/2 inch thick.
Maybe someone can help me calculate the specs.
thomas997
nice haul..
jackinnj
I am gonna guess, using the thermalloy impedance tool, that with only nominal air movement (32 LMF) the C/W is about unity.
Killjoy99
Is there anything else in the power supply that I should spend the time to desolder and keep?
motherone
The toroids and caps might be worth something. You can always use them later in a SMPS or high voltage project (well, the caps at least). Probably the relays as well.
Just be careful -- that stuff can still store a high voltage charge even after being unplugged.
pinkmouse
I'd just shove the whole thing under your workbench, and just raid it for bits as you need them.
karma
its a old apc. i use every part from em. for my projects:)
i still have a box of blue bc caps same size from the last one
about 15 of em:D
and chokes
Page generated in 0.070394039154053 seconds with 17 queries,
spending 0.04977870 doing MySQL queries and 0.02061534 doing PHP things.
