| DC motor PSU - Click HERE for Original Thread |
| analog_sa |
| quote: | | be a good and precise way for driving a (Maxon)DC motor |
I really wouldn't think so. The only advantage it offers compared to linear regulators is increased efficiency which is pretty much irrelevant in this case.
You can possibly build a nice CCS fed shunt regulator but it seems the best (sonic) results for dc motors are achieved by a simple 317 reg supplied from a battery. |
| jackinnj |
the K8004 is a good kit if you want to begin to understand the basics of PWM control -- you can also use PWM for myriad applications BUT...
if you are driving a turntable platter PWM is probably NOT the way to go -- while you can tightly control the pulse width through the error amplifier, you are still pulsing the motor so the speed is always accelerating and decelerating a bit -- the integration is provided by mass and velocity of the turntable platter !
the SG3524 or SG3524, coupled with an H-Bridge chip like the LMD18200 or LMD18201 (or equivalent chips from TI and others) are great devices for robotics. http://www.tech-diy.com/jobo.htm |
| cjunk |
| quote: | Originally posted by analog_sa
Could you please provide some references?
Carlo |
| analog_sa |
Somewhere on Teres site you can find a circuit of Manfred Huber's supply. It is a CCS fed shunt reg with a microcontroller providing some non-essential "cosmetic" functions. A pot can easily replace the MC and remove some potential annoyances in the process.
The 317 circuit is just an implementation of the data sheet. |
