diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > ESLs, planars, alternative technologies
fluorescent ballast for driving esl - Click HERE for Original Thread
tade
I know the ballasts for lights are used to create high voltage. do you suppose one could work for driving an esl? do they rectify?
bear
If you are talking about a bias supply, then there is a vague possiblity... the open circuit voltage for most of them is ~600vac, iirc.
It's not really required, since you can use a simple diode multiplier stack to acheive almost any HV you need to bias an ESL, no significant current is needed.
At least one manufacturer used an AC "wall wart" and a reversed small step down transformer followed by a diode multiplier for the HV bias... resulting ~5kvdc.
To drive an ESL with audio you need a high quality transformer, often people use an appropriate impedance ratio output transformer driven "backwards".
_-_-bear
Page generated in 0.020122051239014 seconds with 16 queries,
spending 0.01142478 doing MySQL queries and 0.00869727 doing PHP things.
