| argonrepublic |
I am going to use burr brown drv134 opamps for a project. ti site schematic shows a cap on each voltage input. Both are 1uf no are details are specified about cap. Maybe decoupling caps are on the output stage, which are specified. Anyway i am a beginner and just want to get the correct caps between power supply and op amps.
Thanks |
| dhaen |
Decoupling requirements are not set in stone. They depend on layout, supply source impedance and other circuit details. Treat these as other opamps. Have a search of the forum for designs and look at what others have done around their opamps, for ideas.
You also might look at another manufacturer's application notes for a functionally equivalent device.
Analog devices make the SSM2142 which is a drop-in replacement for the DRV134. I consider them interchangeable.
SSM2142
NB AFAIK there are no other equivalents.
:cop: Thread moved to Electronics and Parts for bigger a audience |
| argonrepublic |
| I should add that I am using +/-18v to power the op amps. I am just wonering whether caps should be non-polar or polar. Electrolytic or metal film or ? |
| dhaen |
Caps up to 1uF are small enough and affordable in non-polar types. Above this capacity, it is common to use a polar capacitor with a smaller non-polar cap in parallel.
If you are using several chips on the same board close together, it is usually ok to use one pair of larger polar caps, and a pair of smaller non-polar caps per chip. Mount these as close to the chip supply pins as praciticable. Try to keep a low impedance ground plane. |
| pinkmouse |
| If you're driving a cable, I've had good results with 100uF and 0.1uF per rail. If it's just for a phase splitter driving chip amps, as seems trendy at the moment, then 47uF and 0.1uF should be ok. |
