diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Opa549 - Click HERE for Original Thread
ctardi
I'm just learning about making amplifyers. Here is what I have come up with using information from the datasheets, and bigmike216. The input power will be about 18V. The of each channel will first go thru the DRV134, and also a preamp that has not been decided yet. What all changes will need to be made?
bigmike216
first off, the voltage will be + and - 18v, before rectification.. ;)
When I have the pcb's made, it'll be easy as pie to assemble it, won't have to worry about how to wire anything :)
do a forum earch about bridging, also search for opa549 and drv134, there's a ton of information.
Talk to me on messenger or something and I'll help you out
neutron7
if you must use a decoupling capacitor, use it before the DRV because any difference in capacitance will result in different low frequency response on the 2 sides of the bridge. then you will get asymetric output at those frequencies affected
paulb
quote:
Why would the capacitance be any different? If you're referring to the tolerance of the capacitors, it will be a very minor effect on frequency response.
But there should be a capacitor, and resistor to ground, before the DRV134.
ctardi
quote:
I was talking, but it was a one sided conversation. (you left signed into messenger)
A cap and resistor has been added before the 134...thanks. Other than that, does anyone see anything else majorly wrong with it?
bigmike216
the capacitor and resistor need to be on the input.
What are you planning on doing for a power supply?
ctardi
i know... they are on the input in version 1.2
Not sure about the power supply right now, still looking for a transformer.
Page generated in 0.02825403213501 seconds with 17 queries,
spending 0.01112652 doing MySQL queries and 0.01712751 doing PHP things.
