diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Question for op-amp guru's - Click HERE for Original Thread
ALW
I'm looking for an op-amp to replace a TL074 in an active filter application. Any suggestions for quad packages as a drop-in replacement for an existing product?
I haven't really decided on target performance yet, but lower noise JFET types are the immediate goal.
I've had a quick scan through the parametric searches, but would love any other advice from those who've tried alternatives.
A.
mikek
...would generaly avoid quads....try duals eg NE5532.....
Bill Fitzpatrick
You want a drop in replacement so the 5532 is not a contender.
How about the OPA4134?
ThingyNess
I second Bill's suggestion for the OPA4134 - the OPA4132 would work just as well, with better DC precision (less offset, among other things), but if I remember correct, the DIP versions have been discontinued (only the 14-SOIC package is available currently)
johnny1
Bill is right. You won't find anything better with four op amps in the same case.
puppyslugg
LT1362:
http://www.linear-tech.com/prod/dat...ml?datasheet=81
LT1365:
http://www.linear-tech.com/pub/q_sr...duct_family=All
opa42228:
http://www-s.ti.com/sc/ds/opa2228.pdf
Nisbeth
The OPA4132/4 are discontinued in the DIP-14 package. The OPA 4228 should work well instead.
/U.
ALW
Mikek,
I'd normally avoid quads too, but no choice in this case, I need drop-in replacement.
Thanks to everyone else, I'll download data sheets and investigate further, will let you know the outcome. Thanks for taking the time to post.
Andy.
Petter
Search the forum for "Brown Dog" and you will find various adapters. I would go for an adapter that would adapt 4 single SMT units to a quad if available and add local decoupling in the process.
If such adapter is not available I would make one myself. It is not that hard.
Petter
carlmart
AFAIK Brown Dog is not making any singles to quad adapters: only duals.
Which is a pity, because the ART DI/O DAC, which is one of the most modded units right off the shop, uses quads. And one of the better mods is using AD825s.
People are using LT1362/1365 instead, FET biased to class A. But they are expensive quads.
Carlos
Page generated in 0.03039288520813 seconds with 17 queries,
spending 0.01052308 doing MySQL queries and 0.01986980 doing PHP things.
