diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Polarity on OB sub - Click HERE for Original Thread
icebear
Hi
I have OB speakers, and a OB sub. Should the sub be 180 deg out of phase in reference to the rest of the system?
Cheers
bjørn
simon5
No. In phase.
Cal Weldon
icebear,
Is the woofer powered? Does the plate amp have a polarity switch?
If so, just try it both ways and see which way you like it.
Cal
Rudolf
quote:
Any low- or highpass in the sub or the speakers will rotate/shift the phase. You might even get stuck like me:
Having a ~90° phase difference between sub and speakers and only a 180° toggle switch.:xeye:
So if you don´t hear much difference between both polarities - it doesn´t mean you´re deaf!
Rudolf
Page generated in 0.017910957336426 seconds with 17 queries,
spending 0.00657248 doing MySQL queries and 0.01133847 doing PHP things.
Please support our sponsor.
