diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Location of rectifier bridge? - Click HERE for Original Thread
ex192
I plan to build an amplifier based on the audiosector LM3875 kit with an external power supply.
Are there any disadvantages placing the rectifier bridge in the chassis of the amplifier instead of placing it in the power supply chassis?
Thank's for any comments.
Jochen
Nuuk
I've tried both and it doesn't seem to make any difference! ;)
When I put it in the remote PSU casing, I add some smallish (120 uF) caps to the rails. :att'n:
sek
EMI would certainly be an issue. But for the sound quality of the amp it should make no difference.
Sebastian. ;)
AndrewT
maybe a bit late for input here.
when you separate the PSU from the amp keep the AC with the transformer and maintain DC inside the amp enclosure.
That means rectify and smooth inside the PSU. Then run DC lines to amp. More smoothing inside the amp and decoupling on the rails will help again.
I believe local smoothing and rail decoupling will affect the final sound quality of the amp.
Now my question.
All the decoupling (and local smoothing) should run on separate return lines to the master ground.
All signal returns should also run on separate lines to the master ground.
Where do you put the master ground? In the amp or in the PSU?
My preference is in the amp and run a PSU ground to the master ground (star earth).
The safety ground is only needed in the PSU and can be resistor connected to the PSU ground.
Page generated in 0.019521951675415 seconds with 16 queries,
spending 0.00720215 doing MySQL queries and 0.01231980 doing PHP things.
